AFRs in slow motion
Golfpro
If it's going lean when you accelerate and rich when you lift off, I'd say the ECU isn't getting a useful throttle position sensor signal. It never knows the TPS position is changing so it doesn't drop out of closed loop - no extra fuel on acceleration, no injector cut on the overrun. Does it burble and pop when you lift off and engine brake?
Check error codes then get a multimeter on the TPS wire.
-Ian
-Ian
When I lift off it goes very lean (18) for a couple of seconds then it moves quickly to rich (11) for about 10 seconds.
As i said earlier in this thread, and as IanC said, check for error codes, and check that the TPS is showing an increasing/decreasing signal/resistance(can't remember which off hand) and reset the point at which it opens by the manual specs.
Will have a look and see if i can find them.
Does an error code not bring up the triangle light on the dash?
-Ian
I dont have a multimeter so the best thing is probably to bring it back to the mapper to check it out. I have been in touch and he is happy to give it the once over.
Just thought that I would do a bit of research to see if it was something simple I could fix myself. Probably better to leave it to the experts this time.:giveup:
Hopefully sorted now.:D
Took the car to the mapper this afternoon and he could find no obvious mechanical or electrical faults.
He hooked up the laptop to the MAP ECU and did a bit of tweeking. He basically reduced the fuelling as he suspected that the cold weather was causing it to run really rich. I guess that the car was originally mapped in the spring when it was a good bit warmer than it is now. Also we recently built a cold air box with ram air ducts so the cold air is now coming straight in without getting warmed at all passing through the hot engine bay.
We will do a propper winter map in the next few months and run this until it warms up again when we can switch back to the original.
