Boiler power
tbourner
We have a Combi boiler in the kitchen cupboard with a timer box upstairs in the airing cupboard. The plug for the boiler (plugged into a socket that goes straight to the trip marked 'boiler' :D ) has a label on it saying do not unplug!
Does that mean "permanently" or "at all, ever!"?
We were hoping to unplug it for a few mins and take a sneaky feed off it for an outside light. Will it screw everything up if I do or will it just mean the heating won't be on for a few mins?
You want to power an outside light off your ring main?
Best not - it'll want an RCD/RCBO to be safe.
They're usually wired from a ceiling rose! At least all the ones I've seen have been, maybe we've got a dodgy electrician in the area! :D
My idea was if anything went wrong it'd just trip the boiler fuse. Hence I wanted to know why I wasn't allowed to switch it off.
Sorry, yes you're right - outside security lights are often wired straight off the lighting circuits. Outdoors circuits for garden lights would have to be separated.
However, you've made an interesting point - you're going to wire a light to a circuit that says "do not switch off". If the light blows the circuit, you'll knock out your heating with it. Take a look at that link I posted earlier - they suggest you could pass the circuit through a low-rated fuse which _should_ save the main circuit if it goes.
I reckon you should buy a copy of the IEE regs 17 edition and read it!!!!.:rolleyes:
Since you clearly know the answer, why not share it with the rest of us instead of just rolling your eyes?
I guess he's talking about the low rated fuse idea? I don't know though.
Why would an outside light trip anything anyway?
Do you want to wire the outside light in temporary?
What size of MCB(Breaker)is protecting the heating circuit(Should be 6AMP)
You wouldnt do any lasting damage unplugging the combi for a short while some people over elaborate things a tad.
Trust me ive been an electrician for 14years and am now a certifier.
I think it's a 15A, I'll have a look later.
ok mate here you go this is what to do if you must, by the side of the socket you need to put a fused spur, and rate the fuse at 5 amps, even 3 will do if its only a small light,
what the basically means is that should the light blow its the fuse in the spur that will trip as opposed to the main trip going in your consumer unit.
Couple of things that concern me though, is it defiantly a separate feed for the boiler? the reason i ask is combi boilers only need to be rated at 5 amps, therefore it can be spurred from the main ring, either upstairs or down. Now by the letter of the law any new circuit should be protected by an RCD, ie your putting in a new light off of the ring main, however if it was to come from a lighting circuit the circuit is all ready in place, if you get my drift. and remember the IP rating for the outside light, minimum IP44
cheers
Richie
It's a 300W filament halogen thingy, What's an IP? Will it say on the box?
My dad's an electrician but hasn't done it for years, so it'll be safe enough just probably won't follow current regs. We would probably have done a spur off the ring and made it almost as if it's a plug in light with a switch, but the house was built with a joint kitchen and downstairs ring and we've got a max number of spurs already for sockets in the lounge. Hence the boiler plug idea came about.
I've traced the cable from the plug, it goes through a single wall straight into the fusebox cupboard, and into the consumer unit to it's very own switch. IIRC it was 15A but not sure.
Basically it's a bad idea to do what we're planning? And if the house burns down I'm unlikely to get insurance to pay out? :blink: Even though the absolute worst case is the boiler trip goes and the house gets a bit cold for a few hours until I realise it's off and sort something out?
IP rating is just a level of weather proofing, i put up three outside lights today, and they were all IP44 which is fine for what your going to be doing. I know what your saying about the max spurs on the ring but thats for the likes of an additional socket rated at another 13amps, what your going to do with an outside light is fine, put the spur next to the socket and you'll be ok, your dad will be ok with doing it, those 300w halogen lights are old news now, i have just put up some new ones at my place and they are rated at 36 watts, the light output on them is great, they are in the same housing as the 300 watt ones but nearly a 10th of the power consumption, i really like them, will see if i can get you a link for them
richie
O'rrrrrrrrryyyyy... Please do, this interests me with my plans to completely cut power consumption round the house. :)
Never mind : You just posted :)
