tony tt Posted November 17, 2008 Share Posted November 17, 2008 Hi folks im going to be fitting de-cat pipes and restrictor ring shortly to bring my lovely toy to bpu i read somewhere that after doing this it would be wise to reset the ecu! is it worth doing it or does it make any difference? is it something the plebs in a toyota garage could do? thanks any input would be appreciated. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 17, 2008 Share Posted November 17, 2008 Just briefly disconnect the battery or pull the ECU fuses, resetting it will help it to relearn the new boost pattern, but it will only save a bit of time. Quote Link to comment Share on other sites More sharing options...
merckx Posted November 17, 2008 Share Posted November 17, 2008 Remove the EFI No 1 fuse located on the left side of the engine bay under the black plastic cover, I forget exactly how long it needs to be out but 1 min will do the trick. Or disconnnect the battery like Tricky Ricky has suggested. Quote Link to comment Share on other sites More sharing options...
Jake Posted November 17, 2008 Share Posted November 17, 2008 How to reset ECU http://www.mkivsupra.net/vbb/showthread.php?t=116786&highlight=reset+ECU ECU Reset do i need to reset the ECU after decat installation? ECU Reset? Ecu reset which fuses do i pull out? How do you reset the ECU? Quote Link to comment Share on other sites More sharing options...
Jake Posted November 17, 2008 Share Posted November 17, 2008 How to reset ECU ECU reset ECU Reset do i need to reset the ECU after decat installation? ECU Reset? Ecu reset which fuses do i pull out? How do you reset the ECU? Quote Link to comment Share on other sites More sharing options...
tony tt Posted November 17, 2008 Author Share Posted November 17, 2008 excellent cheers lads!!! Quote Link to comment Share on other sites More sharing options...
