ClaireRZ-S Posted November 16, 2008 Share Posted November 16, 2008 Right folks i dont have the car long so only getting around to looking at this (well chris looked at it for me) there seems to be power in the boost controller turns and lights up fine tried to turn the boost up and down and doesn't make a difference anything that we should look at to fix this?? Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted November 16, 2008 Share Posted November 16, 2008 is the piping the right way round? has the cap come off the other nipple on the wastegate actuator? Quote Link to comment Share on other sites More sharing options...
ClaireRZ-S Posted November 16, 2008 Author Share Posted November 16, 2008 (edited) I dont really know much about them to be honest but behind the EBC - 3 cables , 1 for power with socket/plug ends up in the black box in the engine bay (top left of pic). The second one is unused and seen hanging in the pic and the third one runs into the engine bay marked 1 on the pic and finishes up with a T-joint (in pic) Edited November 16, 2008 by ClaireRZ-S (see edit history) Quote Link to comment Share on other sites More sharing options...
hadyn Posted November 16, 2008 Share Posted November 16, 2008 cable disconnected could be the source of your problem... Quote Link to comment Share on other sites More sharing options...
ClaireRZ-S Posted November 16, 2008 Author Share Posted November 16, 2008 Is this what you mean ? http://www.mkiv.com/techarticles/blitz_dsbc/dsbc6.JPG What do i need to look for??? Quote Link to comment Share on other sites More sharing options...
ClaireRZ-S Posted November 16, 2008 Author Share Posted November 16, 2008 cable disconnected could be the source of your problem... Where is that cable suppose to go?? Quote Link to comment Share on other sites More sharing options...
hadyn Posted November 16, 2008 Share Posted November 16, 2008 Is there a black plastic box under the bonnet with Blitz etc stamped on it? Should be visible somewhere.. Quote Link to comment Share on other sites More sharing options...
ClaireRZ-S Posted November 16, 2008 Author Share Posted November 16, 2008 Is there a black plastic box under the bonnet with Blitz etc stamped on it? Should be visible somewhere.. Yeah its in the picture of the engine bay number 2 i posted you can just see the black box to the left Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted November 16, 2008 Share Posted November 16, 2008 is the harness to the black box in the engine bay connected up? you said that there's three cables coming out the back, one should be for power (going to your fuse box) with a black ground wire going to the chassis, then there should be a harness going to the black box, that should go through the firewall into the engine bay, then there should be a black hose(not a wire) going to the intake manifold. All these should be connected for it to work, i cant see how why there should be one hanging down un-connected. Quote Link to comment Share on other sites More sharing options...
ClaireRZ-S Posted December 5, 2008 Author Share Posted December 5, 2008 got it fixed many thanks for your help on this Quote Link to comment Share on other sites More sharing options...
Supra-Dupra Posted December 5, 2008 Share Posted December 5, 2008 It was just the boost hose had come off the nipple (sensor?) inside the ebc, opened it up took out the circuit board and opened the hose clamp then back together and it works. Quote Link to comment Share on other sites More sharing options...
