I've finally got around to spraying my dash
Guest Garfy
Sprayed it in satin black, and very pleased with the results.
Top tip though, Brake fluid works great for getting the rubber stuff off ;)
Before
After
:thumbs:
That looks fantastic Garfy. A really good job. What made you decide to that then?
Thanks Andrew, seeing how much nicer yours looked was the final nail in the coffin for my dash, I know yours isn't black, I did think about doing it a similar colour to yours, but then I thought it just wouldn't match anything else on the car, so went for black.
very nice mate.mines silver at moment but want to
spray it black.
go for it then, it only takes about a day, infact with yours already being sprayed it should be a really easy job
:thumbs:Looks excellent!!!
Did you do any other prep work apart from obviously peeling off the rubber? i.e. A base coat of some sort or primer?
yes, a coat of grey primer first, then rubbed it down and a couple of coats of satin black
