Front wheel snaped off
BJ_dpc
After having a little accident with the sidewalk i've got a car here where the left front wheel snaped off.:(
It's a EU spec car with LHD.I think the parts i need are the same as UK spec or Jpec? Or am i missing something..
I'm looking for the parts that i need to get it on the road again only my English is not that good that i know how the name all the parts that i need. Can anyone help me out?
The wheel snaped off on the hub, so all the bearings are out, steering ?? broke off, suspension , balljoint, fusee etc..
Someone has something laying around or knows where to get it please let me know!
Thanks Bjorn
Edited by BJ_dpc (see edit history)
No problem for becoming a member. But till this point i have no idea how to name all the things i'm looking for so if someone can help me with that, will be great!
Someone was driving the car and he was claiming to drive around 30kph.. i have my doubts!;)
Youll need to check the steering rack isnt damaged and the brake caliper could also have non obvious damage as well where the brake line attaches.
Parts you'll definetly need by the look of it are
Wheel hub (complete)
Upper wishbone
Lower wishbone
Track Rod
Damper (shock absorber)
Brake pipe to caliper
And all the nuts and bolts for the above
This week i will bring the wheels to a repair shop. They did a great job once for me so i hope they can do it again.
The wheelhub still looks ok, steering rack you mean that steel thing that goes from the steeringhouse to the wheel? The brake cilinder still looks fine, only the disc is in 4 pieces.
Will put up some detailed pictures later so you guys can tell me what i need!
i don't think he was going 30kph, because that's slower than 30 mphs and Ive hit the kerb in my little clio ( wen i still had it ) at 60mph and i broke drive shaft in 3 places / wishbone snap straight off / broke the disc in 3 places, just say the wheel ended up underneath the car at the side so just say i done the best job going, and it seems like his done the same.
I would personally replace all of it, although it all looks fine to you and every one esle but you could of done damage that you cant see, that's the mistake i made, thinking this and that was fine when really i put new drive shaft in / wishbone etc and i could never get the tracking right,always shaking coming from the wheel, anti roll bar joint always kept snapping at the link every time i turned corner,
so from experience, i would replace the lot mate to be hones. Save than sorry!
Looks like you have had complete lower ball joint failure and this has ripped the other fittings clean out......:(
I would get as much of that area replaced if you could. If wan't some second hand parts then I would contact either Keron or Jezz on here. The price of new parts from Toyota will not be cheap. They quoted me £340 just for a lower wishbone....:rolleyes:
H.
