Endeavour launch tonight
JustGav
  • Replies 90
Ah, 23 minutes till launch, midnight tonight if I'm right in what I just heard...
Not quite, they run two clocks...
One is a real clock, the other is the launch clock.
The launch clock which is one you are seeing is paused at certain times for activities to take place.
T-20 minutes and holding
This built-in hold typically lasts 10 minutes.
* Shuttle Test Director conducts final launch team briefings
* Complete inertial measurement unit preflight alignments
T-20 minutes and counting
* Transition the orbiter's onboard computers to launch configuration
* Start fuel cell thermal conditioning
* Close orbiter cabin vent valves
* Transition backup flight system to launch configuration
T-9 minutes and holding
This is the final built-in hold, and varies in length depending on the mission.
* The Launch Director, Mission Management Team and Shuttle Test Director poll their teams for a go/no go for launch
T-9 minutes and counting
* Start automatic Ground Launch Sequencer
* Retract Orbiter Access Arm (T-7 minutes, 30 seconds)
* Start Auxiliary Power Units (T-5 minutes, 0 seconds)
* Arm Solid Rocket Booster range safety safe and arm devices (T-5 minutes, 0 seconds)
* Start orbiter aerosurface profile test, followed by main engine gimbal profile test (T-3 minutes, 55 seconds)
* Retract Gaseous Oxygen Vent Arm, or "beanie cap"
(T-2 minutes, 55 seconds)
* Crew members close and lock their visors
(T-2 minutes, 0 seconds)
* Orbiter transfers from ground to internal power
(T-50 seconds)
* Ground Launch Sequencer is go for auto sequence start (T-31 seconds)
* Activate launch pad sound suppression system
(T-16 seconds)
* Activate main engine hydrogen burnoff system
(T-10 seconds)
* Main engine start (T-6.6 seconds)
T-0
* Solid Rocket Booster ignition and liftoff!
Here you go...
I can only imagine how terrified I would be strapped on top of a bomb that once you lit, there's no turning back.
Heros all :respekt:
Update... just had a little problem but are good to go in 9 mins.
Not only that, but they don't even fly the damn thing, it is controlled from the ground :) Given a chance, I'd happily do it, in fact I'd love to do it. It must be the adrenalin rush of a life time. 7 million pounds of thrust.... now that is some serious ummmphh
