botachi Posted November 14, 2008 Share Posted November 14, 2008 (edited) Hey guys was wondering what's a safe boost level to run with the oem j-spec twins assuming the condition of the turbines are OK? I've got all the fuelling I need (800cc SARD injectors, Walbro pump, 6-an fuel lines) and Greddy E-Manage to map things accordingly, just need to know what's a safe boost level for these babies. People in the US say no more than 1 bar for the J-Spec twins as opposed to USDM spec twins able to do 18 psi reliably, roughly 1.35-1.4 bar. That's coz the J-spec items aren't as strong as the USDM ones. Here I've seen some guys boosting 1.2 bar on what appears to be J-Spec twins so am unsure what to do. Currently doing 1 bar now, and very happy But if MORE can be had, why not right lol ) My MKIV has no cats and has a straight through exhaust from the turbos to the muffler Edited November 14, 2008 by botachi (see edit history) Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted November 14, 2008 Share Posted November 14, 2008 1.2 bar Quote Link to comment Share on other sites More sharing options...
botachi Posted November 14, 2008 Author Share Posted November 14, 2008 Thanks Gaz, was trawling through the search engines and hadn't found the topic I was searching for before you posted. Thanks mate! Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 14, 2008 Share Posted November 14, 2008 Can i ask why you are using 800cc injectors on a BPU Supra? seems a little overkill, are you going single turbo in the near future? Quote Link to comment Share on other sites More sharing options...
Thorin Posted November 14, 2008 Share Posted November 14, 2008 1.2bar. ...and yes, a little odd to be running bigger injectors with stock turbo's unless you're planning to go single. Quote Link to comment Share on other sites More sharing options...
