staceymr2 Posted November 13, 2008 Share Posted November 13, 2008 I was at Brands Hatch yesterday and was on and off track for most of the afternoon. As I come into one of the corners I lost all eletrical power and rolled onto the grass. I had not ignition power at all, no windows, no wipers. All my lighs still worked and the light for my door open was ok. Got it back into the pits and found that he AM2 fuse (7.5amp) had blown. Replaced the fuse, turned the ignition on and it blew stright away. Had a look at it tonight Put new fuse in turned ignition on.......fuse ok Crank car over, turned 1-2 times...... fuse blew (New fuse) Took starter relay out, go to turn over fuse ok, relay back in, turn over fuse blew. (New Fuse) Turn ignition on....use eletric windows..fuse blows stright away (New Fuse) Turn ignition on....use wipers..fuse blows.... Everytime you draw power it blows Could it be a relay? If I leave the starter relay out and use windows it blows. Im going to try and take both wiper and window fuses out as I do belive the amp on them are higher. If I crank it and the am2 fuse is ok then it narrows it. If it blows, then going to test the 3 main relays in the engine bay (Ignition Main, EFI And COR) What has crossed my mine is the this....might be very way off mark. The car got very very hot as was on track about 2 half hours. On for about 20-25min and off for about 10-15. The turbo would of got very hot. Just below the Turbo is the starter motor. If i melted/damaged the wires or even the starter motor its self could this cause the problems im getting Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted November 13, 2008 Share Posted November 13, 2008 First thing what does the AM2 fuse do? Does sound very much like a short circuit. Or an elecrical fire... Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted November 13, 2008 Share Posted November 13, 2008 worth a read http://toyotaownersclub.com/forums/index.php?showtopic=6852 Quote Link to comment Share on other sites More sharing options...
staceymr2 Posted November 15, 2008 Author Share Posted November 15, 2008 I think I have found the problem. The alternator earth was off and its also blown a 120amp fuse under the bonnet. So got one on order and im hopeing that should fix her Quote Link to comment Share on other sites More sharing options...
staceymr2 Posted November 18, 2008 Author Share Posted November 18, 2008 Well thank you for your help. She is all fixed Quote Link to comment Share on other sites More sharing options...
Tom Posted November 18, 2008 Share Posted November 18, 2008 any pics from the trackday??? Quote Link to comment Share on other sites More sharing options...
staceymr2 Posted November 18, 2008 Author Share Posted November 18, 2008 I have but did not know if I was aloud to post them as its an mr2. lol Mods.....Do you want me to post them here or Multi section??? Quote Link to comment Share on other sites More sharing options...
Tom Posted November 18, 2008 Share Posted November 18, 2008 (edited) I have but did not know if I was aloud to post them as its an mr2. lol Mods.....Do you want me to post them here or Multi section??? dont be silly, of course you can its a Toyota after all go for the multimedia section Edited November 18, 2008 by Tom (see edit history) Quote Link to comment Share on other sites More sharing options...
staceymr2 Posted November 18, 2008 Author Share Posted November 18, 2008 Iv put them up in off topic :-) Quote Link to comment Share on other sites More sharing options...
