FAO CW - Abbey Msport Dyno
Branners
Chris - can you give us your thoughts on this dyno? If its like all the rest then just say 'its like all the rest'
ABBEY,S DYNO
GTR mob,
DYNAPACK 5302
yes the dyno has arrived and we are just finishing off the
dyno room. Fully sound deaden , exhaust extraction system
2 supply fans max air movement 54000 cubic metres a hour
2 extraction fans max air movement 54500 cubic metres a hour
able to change the air every 3 secs in the dyno room, same as
travelling at 140 mph.
We will be running the dyno at TRAX at the week end , YES
it is portable , can be hired at a reasonable rate. to use
at your premises.
http://www.dynapack.com.
as used by NISMO in japan.
Can't comment on Branners's question but I read in either RaceTech or Racecar Engineer about a new dyno in the UK which can hold 1800RWHP (they are able to pin the car to the rollers to test it.
I believe its 1200RWHP and 600FWHP
It begins with a G....can't remember - I did mention it in a thread I wrote in General Discussion have a search....
Guest Terry S
Alex I need more info. Any ideas of names or numbers for these places. I will need to do some fine tunning. It's either a decent RR or Bruntingthorpe & a laptop:eek:
Originally posted by Terry Saunders
Alex you are a star
I'm not used to praise...in fact that might have been a first! :eek:
If I remember correctly it a temperature controlled room and able to cope with "high speed" runs...the car pictured on the rollers was a Porsche GT2 full works prepared race car.
Its the only one in the world of its type...but that could be good or bad!
When you get your car up and running you and Leon should have a face off down at G-Force! :D
