Dash lights - HTR/AC controls - question
Guest Concord Mike
Guest Concord Mike
I just purchased a 1994 Supra Sport Roof. I noticed that the lights embeded on the Htr / AC controls do not light. The lights above each button lights, for example if you press the AC button a light come on above the button. I check the fuses I thought would be associated but all look good.
Since I've not had or been in a Supra at night I am not even sure that the lights should be lit but they look like they should. Can someone give me a directions to look in. It might be that a bulb is out behind the dash which will open a whole new set of challanges for me. Thanks for your response. Concord Mike
