bright 1 Posted November 12, 2008 Share Posted November 12, 2008 Hi everybody, Im getting a knocking noise coming from front of car, when pulling away at full lock, almost feels like the wheels are hopping, any ideas engine mounts bushes etc, if so I live in bristol and does anyone know a good garage that I could check out. Thanks Quote Link to comment Share on other sites More sharing options...
Nic Posted November 12, 2008 Share Posted November 12, 2008 Common cause of knock on full lock is loose sub frame or suspension bolts. Get the car on a ramp and get all the bolts torqued up to see if it cures the problem, also check for play in all the suspension bushes/joints. Quote Link to comment Share on other sites More sharing options...
bright 1 Posted November 12, 2008 Author Share Posted November 12, 2008 Thanks Nic Will try to get it in the air the weekend Quote Link to comment Share on other sites More sharing options...
bright 1 Posted November 13, 2008 Author Share Posted November 13, 2008 Does anyone know what they should be torqued upto? Quote Link to comment Share on other sites More sharing options...
Rob Posted November 13, 2008 Share Posted November 13, 2008 TORQUE SPECIFICATION Part tightened N·m kgf·cm ft·lbf Front Hub nut 103 1,050 76 Lower suspension arm x Suspension crossmember 226 2,300 166 Lower suspension arm bracket stay Bolt 44 450 32 Nut 59 600 43 Tie rod end lock nut 56 570 41 Axle hub lock nut 199 2,030 147 Upper suspension arm x Sub-frame 164 1,670 121 Lower suspension arm x Shock absorber bracket 52 530 38 Tie rod end x Steering knuckle 49 500 36 Steering knuckle x Upper suspension arm 103 1,050 76 Steering knuckle x Lower suspension arm 125 1,270 92 Brake caliper x Steering knuckle 118 1,200 87 ABS speed sensor x Steering knuckle 7.8 80 69 in.·lbf Upper suspension arm x ABS speed sensor wire harness clamp 5.4 55 48 in.·lbf Front shock absorber x Body 35 360 26 Front shock absorber x Lower suspension arm 143 1,460 106 Front shock absorber x Suspension support 29 300 22 Stabilizer bar link x Shock absorber bracket 74 750 54 Stabilizer bar link x Stabilizer bar 74 750 54 Stabilizer bar bracket x Body 18 180 13 Steering knuckle x Brake dust cover 8.0 85 74 in.·lbf Quote Link to comment Share on other sites More sharing options...
bright 1 Posted November 13, 2008 Author Share Posted November 13, 2008 Good man Thanks Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted November 14, 2008 Share Posted November 14, 2008 I've got some "knocking" that up front right sounds like something is grinding a bit. In the back i've also got some knocking in both sides but only when its raining (?). I've recently had my dampers changed, so can this be an issue with bolts not being torqued correctly? Fx too much/litte or if thightened when the wheel is not standing on ground/lift? Quote Link to comment Share on other sites More sharing options...
