xeno Posted November 12, 2008 Share Posted November 12, 2008 Hi.. I have just received my DSC-TSD form Thor. The car still reads in Km/Kmh and I wanted to convert it, so thought I may as well go for the combined unit with TSD for the extra £30 odd quid. I don't know if the car is already delimited or not, as I've not driven it fast enough to know. Would it cause problems if I hooked up the TSD if there was already one in operation? At worst I'll just hook up the DSC. After all I've not reached the speed limiter speed, yet! Regards Terry. Quote Link to comment Share on other sites More sharing options...
stevie_b Posted November 12, 2008 Share Posted November 12, 2008 Hard to say whether the existance of another TSD would cause problems. Have a look behind the dash and around the ECU (in the passenger footwell). If you don't see any small plastic devices spliced into the loom, chances are you don't have a TSD fitted. I'd just fit the Thor one properly (i.e. so the TSD part works as well), and take it from there. Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted November 12, 2008 Share Posted November 12, 2008 why dont you just remove the old one while your installing the new one (if yoiu find it has one already that it) Quote Link to comment Share on other sites More sharing options...
Luka-P Posted November 12, 2008 Share Posted November 12, 2008 You'll have to wire the new one into where the old one would be, if there is an old one. Quote Link to comment Share on other sites More sharing options...
xeno Posted November 12, 2008 Author Share Posted November 12, 2008 Right. Sounds like I should find an existing one, if it's there. In which case I will do as advised and remove any existing one and wire the new one in. I also have a Fcon-V wired in to the stock ECU. I'm assuming this makes no difference to the install? Cheers. Quote Link to comment Share on other sites More sharing options...
