BlackWatch66 Posted November 12, 2008 Share Posted November 12, 2008 hi all, just wanted to know if anyone has had this noise before- when i rev my engine or accelerate hard, a noise that can only be described as running water, seems to come from behind the dash, its like if you have a tap on in the bathroom:blink:? any help greatly appreciated! Link to comment Share on other sites More sharing options...
RedM Posted November 12, 2008 Share Posted November 12, 2008 Sial? Link to comment Share on other sites More sharing options...
Mike Posted November 12, 2008 Share Posted November 12, 2008 a small family of rats have installed a bathroom in your dash? Link to comment Share on other sites More sharing options...
mawby Posted November 12, 2008 Share Posted November 12, 2008 Air in the cooling system? Link to comment Share on other sites More sharing options...
michael Posted November 12, 2008 Share Posted November 12, 2008 Air in the cooling system? What he said, bleed the coolant to remove any air locks and see if it stops. Link to comment Share on other sites More sharing options...
Stonkin Posted November 12, 2008 Share Posted November 12, 2008 i had this in an old astra, sounded like a waterfall under the bonnet, worse when cold. Im sure its a different issue, as it also used to overheat to buggery. It was a banger/run around so didnt really care, but eventually the head gasket went and car got scrapped. This is obviously worse case scenario. I'll shut up now Link to comment Share on other sites More sharing options...
anton Posted November 12, 2008 Share Posted November 12, 2008 Id thought it would be a coolant problem. If it is, it needs sorting asap or youll blow your rad Link to comment Share on other sites More sharing options...
michael Posted November 12, 2008 Share Posted November 12, 2008 And check your rad cap is sealing OK. Link to comment Share on other sites More sharing options...
BlackWatch66 Posted November 14, 2008 Author Share Posted November 14, 2008 And check your rad cap is sealing OK. rad cap seems to be leaking slightly , do you recommend i replace the rad and the cap? Link to comment Share on other sites More sharing options...
tooquicktostop Posted November 14, 2008 Share Posted November 14, 2008 rad cap seems to be leaking slightly , do you recommend i replace the rad and the cap? Replace with a stock rad cap, this may cure the problem, dont fit an uprated cap, it may cause other issues Link to comment Share on other sites More sharing options...
SteveR Posted November 14, 2008 Share Posted November 14, 2008 rad cap seems to be leaking slightly , do you recommend i replace the rad and the cap? Don't replace the rad if it's only the cap that's leaking! Link to comment Share on other sites More sharing options...
