What's wrong with your Supra?
AndrewOW
  • Replies 195
  marc_p said:
Get yourself a veilside kit, give the car a bloody good buff and get yourself down to the local McDonalds :D
THAT explains it then! Even if you turned up in a shed that a Barry would find painful, you could score for a burger and a vanilla milkshake :D
The dash needs replacing (in the process), the manifold gasket needs replacing (doing at the mo), there is an annoying squeek in the boot, it needs converting to mph, the steering wheel needs replacing, the arm rest needs replacing (thanks Jezz for the new one), my battery isn't big enough (new one on way) and its wheels are too small.
Apart from that... she looks pretty and its the only one in my area... Only ever seen 2 other supras on the road... 1 in America and 1 down south
My passenger door is alightly missaligned somehow and needs a bit of a slam to close sometimes. And from ouside it looks (to someone as picky as myself) as if its not closed properly although it is.
My drivers door also rubs slightly on the skirt although its genuine oem.
My drivers side doorcard has an elbow dent.
No front door speakers! Stock radio is also a bit pants sometimes.
Overheats a bit randomly in the summer.
Slight crack in the laquer on the rear bumper and a stone chip on the front (cant see it unless your under the car though!)
Also the active spoiler is worn on one side from the speed bump at the end of my road.
Other than that its perfect :p
Spoiler is in Matt Black
Front bumper is in primer soon to be matt black
Crack in side skirt
Battery isn't charging properly (possible alternator problem)
2nd turbo isn't working
Other than that its pretty good lol. The sooner the new year and my re-spray comes the better :)
  Mike said:
Check your subframe ;)
:D
Nope my Subframe is Ok, it's interior rattles and vibrations that my Supe suffers with and it's getting on my bloody nerves!!
  Missile said:
Got one of these you can have. :)
Edit, Not sure its going to be the same as yours. Mines out of an Import not a vvti ...
Ahh, is it for a facelift Supra??
If it is, that'll be fine...:)
How much are you looking for it Missile?? :)
My son is always pinching it!! I cant find a baby seat to fit in it.
Only other real problem is - the drivers side window leaks slightly, think the channel in the rubbers may be blocked no matter how many times i try to unblock it, it still happens.
1, Drivers window needs to be re-aligned.
2, Power steering pump pulley is noisy when cold.
3, REAS suspension needs to be replaced next year.
4, Boot doesn't pop open far enough when released from inside, so you have to use the key.
5, Couple of plastic bolts missing from the inside panels.
6, Stonechip on the windscreen needs 'resin' fix.
7, Its not yet wearing a set of 18" Volks SF Challenge wheels with Bridgestone RE050A's ;)
8, The bass speakers are not powerful enough to puncture my ear wax.
9, The RSR exhaust back end is no longer shiny.
10, The rear number plate is too big.
