sidewaysdan Posted November 10, 2008 Share Posted November 10, 2008 (edited) does anyone know why the piping on my turbo comes out the top. as i want to spin the housing so i can put my new bonnet on without cutting bits off. ive seen the same kit on a few supra's like the amuse supra but didnt know if there is a reason why the kit is like this. Edited November 10, 2008 by sidewaysdan (see edit history) Quote Link to comment Share on other sites More sharing options...
JamieP Posted November 10, 2008 Share Posted November 10, 2008 Looks like the turbo runs an internal wastegate, id say it would be to do with that. Quote Link to comment Share on other sites More sharing options...
gaz1 Posted November 10, 2008 Share Posted November 10, 2008 it was done like that because whoever fitted it did not think they had clearance going under, but everyone elses does;) Quote Link to comment Share on other sites More sharing options...
gaz1 Posted November 10, 2008 Share Posted November 10, 2008 Looks like the turbo runs an internal wastegate, id say it would be to do with that. good thinking:D Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted November 10, 2008 Author Share Posted November 10, 2008 Looks like the turbo runs an internal wastegate, id say it would be to do with that. hi jamie.it is a internal wastgate but the bolts do still line up if i spin the housing though, Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 10, 2008 Share Posted November 10, 2008 You should still be able to rotate the compressor housing, and still be able to bolt the actuator onto it. Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted November 10, 2008 Author Share Posted November 10, 2008 You should still be able to rotate the compressor housing, and still be able to bolt the actuator onto it. yes i can do that.but didnt know if there was a reason why the piping comes off like that. Quote Link to comment Share on other sites More sharing options...
JamieP Posted November 10, 2008 Share Posted November 10, 2008 hi jamie.it is a internal wastgate but the bolts do still line up if i spin the housing though, Ok if its not that it may still be a clearance issue, have you tried taking the ic pipework off and clocking the turbo round? the manifold you have makes the turbo sit parallel and close to the block. Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted November 10, 2008 Author Share Posted November 10, 2008 Ok if its not that it may still be a clearance issue, have you tried taking the ic pipework off and clocking the turbo round? the manifold you have makes the turbo sit parallel and close to the block. no not yet but looking at it i think it will clear. Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted November 10, 2008 Author Share Posted November 10, 2008 no not yet but looking at it i think it will clear. this is same turbo on a car paul whiffin has for sale Quote Link to comment Share on other sites More sharing options...
