phat supra Posted November 10, 2008 Share Posted November 10, 2008 as above been losing coolent for the past few days now and my car seems to want to steem up all the time any idears thanks lee Quote Link to comment Share on other sites More sharing options...
JustGav Posted November 10, 2008 Share Posted November 10, 2008 Heater matrix sounds like it has gone pop... You running an uprated 1.3bar rad thermo? Quote Link to comment Share on other sites More sharing options...
phat supra Posted November 10, 2008 Author Share Posted November 10, 2008 Heater matrix sounds like it has gone pop... You running an uprated 1.3bar rad thermo? not sure mate just the standard one i think well i ant changed it Quote Link to comment Share on other sites More sharing options...
phat supra Posted November 10, 2008 Author Share Posted November 10, 2008 how bad of a job is it ? any idear how much a new one is thanks Quote Link to comment Share on other sites More sharing options...
gaz1 Posted November 10, 2008 Share Posted November 10, 2008 very bad as the whole dash needs to come out, i remember qoutes around £1000 but noone really wanted to do it Quote Link to comment Share on other sites More sharing options...
SteveR Posted November 10, 2008 Share Posted November 10, 2008 Go see if your passenger footwell is damp/wet. The heater matrix lives above that. It's a pig of a job; have a search, there is a how to thread. Quote Link to comment Share on other sites More sharing options...
mr lover Posted November 10, 2008 Share Posted November 10, 2008 look if you dare http://www.mkivsupra.net/vbb/showthread.php?t=127044 Quote Link to comment Share on other sites More sharing options...
JustGav Posted November 10, 2008 Share Posted November 10, 2008 Come on people, it isn't really that bad a job... Yes it can take a bit of time, but doable in a day. Quote Link to comment Share on other sites More sharing options...
phat supra Posted November 10, 2008 Author Share Posted November 10, 2008 just goin to feel me carpet will be back in a mo Quote Link to comment Share on other sites More sharing options...
gaz1 Posted November 10, 2008 Share Posted November 10, 2008 Come on people, it isn't really that bad a job... Yes it can take a bit of time, but doable in a day. fair play for offering to help him do it gav, hats off to you:eyebrows: Quote Link to comment Share on other sites More sharing options...
JustGav Posted November 10, 2008 Share Posted November 10, 2008 fair play for offering to help him do it gav, hats off to you:eyebrows: Hehehehe, not quite , not driving to Cheshire for a matrix (But I've done 3 so far and they definitely get easier) Quote Link to comment Share on other sites More sharing options...
phat supra Posted November 10, 2008 Author Share Posted November 10, 2008 well footwell is bone dry could it be an old rad cap Quote Link to comment Share on other sites More sharing options...
gaz1 Posted November 10, 2008 Share Posted November 10, 2008 yes you can be losing fluid through a old perished cap, deffo worth replacing;) Quote Link to comment Share on other sites More sharing options...
Jamesy W Posted November 10, 2008 Share Posted November 10, 2008 Very likely. I've had two in 6 months. Also worth checking that you have coolant in your expansion bottle. Quote Link to comment Share on other sites More sharing options...
JustGav Posted November 10, 2008 Share Posted November 10, 2008 (edited) To be honest chap, it is very classic signs of the matrix about to go bang, seriously, the water system on the supra is very good apart from the two weakness points. A. Heater matrix core B. Top portion of the rad cracks Usually made worse by using an aftermarket rad cap. as above been losing coolent for the past few days now and my car seems to want to steem up all the time any idears thanks lee Edited November 10, 2008 by JustGav (see edit history) Quote Link to comment Share on other sites More sharing options...
phat supra Posted November 10, 2008 Author Share Posted November 10, 2008 any idears how much i need to be saving up for a new matrix Quote Link to comment Share on other sites More sharing options...
Dazzi Posted November 10, 2008 Share Posted November 10, 2008 Usually with any car, loss of coolant could be the headgasket. Quote Link to comment Share on other sites More sharing options...
hadyn Posted November 10, 2008 Share Posted November 10, 2008 Are you losing coolant from the expansion tank or the rad itself? If it's just emptying the expansion tank, its probably a knackered cap Quote Link to comment Share on other sites More sharing options...
phat supra Posted November 11, 2008 Author Share Posted November 11, 2008 Usually with any car, loss of coolant could be the headgasket. just had the valve stem seals done will new hks head gasket at the same time so dont think it will be that Quote Link to comment Share on other sites More sharing options...
phat supra Posted November 11, 2008 Author Share Posted November 11, 2008 Are you losing coolant from the expansion tank or the rad itself? If it's just emptying the expansion tank, its probably a knackered cap well had just been toppin up the expansion tank but needed to top the rad up last night about 3 cups to fill it back up do toyota stock the standard caps anyone got a part number thanks lee Quote Link to comment Share on other sites More sharing options...
markssupra Posted November 11, 2008 Share Posted November 11, 2008 well had just been toppin up the expansion tank but needed to top the rad up last night about 3 cups to fill it back up do toyota stock the standard caps anyone got a part number thanks lee Give Steve Manley a call on 01865 291333 at Inchcape Toyota and say your a member on here. He will sort you out without needing a part number Quote Link to comment Share on other sites More sharing options...
Burna Posted November 11, 2008 Share Posted November 11, 2008 well had just been toppin up the expansion tank but needed to top the rad up last night about 3 cups to fill it back up do toyota stock the standard caps anyone got a part number thanks lee Part number = 16401-62100 Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 11, 2008 Share Posted November 11, 2008 Check the pipes that go from the back of the head to the heater matrix, if the head has been off recently;) Quote Link to comment Share on other sites More sharing options...
Guest pitstopralph Posted November 12, 2008 Share Posted November 12, 2008 The clue bud, is in the fact that the car wants to steam up all the time, This must mean hot water/steam is inside the car, therefore the matrix is by far the most obvious culprit! Quote Link to comment Share on other sites More sharing options...
