High Idle- again
supspower
OK the search ive narrowed it down to either two things.....ICV or the TPS though im not 100% sure
Does anyone have a spare ICV or TPS for the 94 NA supra or someone in the cambridgeshire area that doesnt mind swapping to see if theres a difference? (id drive to you ofcourse )
cheers all
Guest skylined_gtr
Hi mate
I'm near St Neots, have a 1JZ-GTE Soarer, came across your post as I was looking for info on the TPS resistance readings.
Welcome to pop over and measure and compare if you like? I have a rough idea on what they should be or if you have a multi-meter/voltmeter I can tell you what the resistance needs to be?
Latz
