StuartW Posted November 10, 2008 Share Posted November 10, 2008 Need to find where the folding mirrors relay is situated please? Tried a search and read forums for hours with no positive results Quote Link to comment Share on other sites More sharing options...
JustGav Posted November 10, 2008 Share Posted November 10, 2008 (edited) I'd hazard a guess that it will be on the driver side footwell electrics, I will check my diagrams a bit later. http://www.slipstreem.net/mkivsupra/manuals/Wiring%2520Diagrams.pdf pg 185, gives you the wiring diagram, you may need to match it up with the loom connectors further up in the doc. Looking at it, there isn't a relay persay... will look closely when I'm not at work. Edited November 10, 2008 by JustGav (see edit history) Quote Link to comment Share on other sites More sharing options...
osso Posted November 10, 2008 Share Posted November 10, 2008 The relay that operates the motor directly is inside the mirror itself.. Its a door card off jobby. Quote Link to comment Share on other sites More sharing options...
StuartW Posted November 10, 2008 Author Share Posted November 10, 2008 The relay that operates the motor directly is inside the mirror itself.. Its a door card off jobby. So i am lookin for a relay that dont exist? Quote Link to comment Share on other sites More sharing options...
JustGav Posted November 10, 2008 Share Posted November 10, 2008 Looking at the wiring diagram, it is simply a power feed to the switch unit, which then goes directly to the mirror unit...so nope I don't think there is a relay Quote Link to comment Share on other sites More sharing options...
