Big Ian Posted November 9, 2008 Share Posted November 9, 2008 my Supra read's in Kph both speedo and ODO read out, is it worth converting to Mph? my speedo has both Kph & Mph on it but none of them read the proper speed, following folk at 30mph show's 36mph & 55Kph on my speedo. is there a way i can just have the speedo reading more true? thanks pic of my speedo display Quote Link to comment Share on other sites More sharing options...
JustGav Posted November 9, 2008 Share Posted November 9, 2008 You will probably find the car has a limiter around 120 as well. If it doesn't bother you then don't fit a convertor/delimiter. Quote Link to comment Share on other sites More sharing options...
MrRalphMan Posted November 9, 2008 Share Posted November 9, 2008 All cars are slightly over the correct speed on the speedo. Your car sounds about right, do you have after market wheels that are a different diameter? Quote Link to comment Share on other sites More sharing options...
Big Ian Posted November 9, 2008 Author Share Posted November 9, 2008 thanks for the reply i'm running standard 16" with proper profile tyre's the top-end speed dose'nt bother me that said, i have had my car off the clock (on a private test track;) ) Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted November 9, 2008 Share Posted November 9, 2008 You could use one of those THOR/TRL signal converters, they have an adjuster which allows you to set your speedo accurately. Try setting against a GPS such as a Road Angel on a straight M-way. Quote Link to comment Share on other sites More sharing options...
Big Ian Posted November 15, 2008 Author Share Posted November 15, 2008 can anyone tell me, from looking at the picture i posted (above) is my speedo dial an after market item or a standard one? just that i was looking on ebay at this: http://cgi.ebay.co.uk/Toyota-Supra-Face-Dial-Facia-Easy-to-Replace-Jap-Impor_W0QQitemZ170278896925QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item170278896925&_trksid=p3286.c0.m14&_trkparms=72%3A1301%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318 and it look's the same as mine, just wondered if someone has fitted it to my car (kinda on the cheap?) and if it is an after market do you think i'd be better looking for either a UK speedo face or should i change the dial face in my car to one that only show's MPH Quote Link to comment Share on other sites More sharing options...
