Sticking Fiberglass
terribleturner
Slightly off topic i guess, but anyways. I have a 2 pod a pillar in the car and im having trouble getting it to stay attached. At the moment i have some sticky back platisc pads holding it on, but i think im in need of something better. Anybody got an helpfull hints and tips as to how to keep the pods in place??
Depends how permanent you want it to be. You could try some heavier duty double sided tape. Like the stuff people stick number plates on with if they dont want bolts showing.
Another way would be to screw it on. Using a couple of discreetly placed screws the same colour as the pod and it should look fine.
Just my 2p!
J4CK50N
I have some loctite 422 instant adhesive at my disposal, of which I could potential acquire????? Wanna give that a shot??
Its a very high viscosity glue type stuff used to bond metals, rubbers and plastics???
The only trouble is, may be unbondable once applied??? :) :thumbs:
May try and find the tape tomorrow and have a go. I didnt really want to use screws, but if you recon it's not that visable Suprchargedtt then i may well have a go.
And Sabrina, may do the glue only for the last resort.
Cheers
i was doubtfull too but i had the same problem, mine kept falling off! If you look at the furthest point up, underneath the first pod then thats where mine is and as i sais you really cant see it, the bulge from the pod keeps it well hidden, if i had my car with me id take a pic so you could see, if it helps?
