Battry Drain - Can I use this to check?
marbleapple
Hi Guys,
I have one of these (see pic below) and was wondering if it is the right tool to check if there is a battery drain? I have presumed that the fault is the alternator but I just thought this evening that it might be my alarm (although a new Bosch battery shouldn't drain in under 2 days surely?)
yeah one of those is fine
Great thanks.
Presumably though the battery needs to be fully charged?
My battery has gone flat in 2 days... can't work out if it is a drain (must be massive to flatten a battery in 2 days), the battery is faulty (less than 3 months old) or there is a small drain and the alternator isnt working well (since I jumped it Saturday and it worked on Sunday).
leaving my sidelights on flatten my battery in half and hour.
use the fluke when the battery is fully charged to see if it holds the load
check volts and amps
then when the engine is running it should read more then 12 volts
put various loads on the battery and see if there is a drop
if the car runs after you have started, the alternator is doing its jobs
but all he needs to check is the voltage in the battery and if there is any voltage drop.
so the greater the voltage the greater the flow of current
He wants to check if there is any drain when the ignition is off. Only way to do that is to check the amps.
  • 3 weeks later...
all very technical here, quick and easy test is disconnect all known power usage bits on your car i.e sub amps,alarm etc then loosen poss bat terminal then tap it on and off the poss batt terminal if it sparks somethin is drawing current ( or you have a short on your wiring circuit someware ( good luck in finding that one(1st start with moving bit i.e door looms boot heating windows loom etc)))
