Injector Duty Cycle
Graham Rudd
I want to make a device to measure the duty cycle of an injector but I'm not 100% certain of how the duty cycle is measured, I *think* I know, but lets make sure.
To get the duty cycle percentage is it as simple as measuring the pulse width and dividing by the pulse width + the time until the next pulse? Or is there some subtlety I'm missing?
i.e.                                                 pulse width
       duty cycle%  =                       ---------------
                             pulse width + time measured until next pulse
Any help would be much appreciated. If anyone has any good links to technical articles on this kind of thing then that would be fantastic.
Many thanks,
Graham
Duty Cycle = Pulse Width on ON period (s)
                   ---------------------------------            X 100%
                   Period (s)
Where Period is the time between two +ve rising edges (or two -ve falling edges, either will do)
Duty cycle is the ratio of the ON period with respect to the total period of the waveform.
So if the injectors are being pulsed at 1000Hz then the period is 1/1000 = 1ms and if they are on for 0.5ms then the Duty Cycle is obviously 0.5ms /1ms *100% = 50%
Similarly if they are on for 0.20ms and the period is 0.5ms ( then the duty cycle is 40%)
See http://www.trlperformance.com/afri.html
regards
Pete
