Dash Rendar Posted November 4, 2008 Share Posted November 4, 2008 My previous XS Power manifold developed a small split at the join. I bought a new one to replace it (other makes were well out of my price range), and had Toyota GT fabricate a support for, as recommended by Chris Wilson. James at Toyota GT was kind enough to take photos of the work as they went along. You can see the fabricated support in a couple of these pictures, and I quote... "it will support the world!" I can't really tell what's going on in a lot of these photos, but I thought you guys might be interested. BTW, I've still got the old manifold available if anyone wants it. It would need a minor bit of welding, but this one is flush on all edges, so you'd save a fortune over buying a new XS Power manifold and then spending a couple of hundred extra getting it machined, like I had to. (But yes, all in it was still only a third the price of buying a BL manifold *without* any custom support.) http://supra.just2good.co.uk/myBlackSingle/toyotaGT/workshop002.JPG http://supra.just2good.co.uk/myBlackSingle/toyotaGT/workshop004.JPG http://supra.just2good.co.uk/myBlackSingle/toyotaGT/workshop006.JPG http://supra.just2good.co.uk/myBlackSingle/toyotaGT/workshop009.JPG http://supra.just2good.co.uk/myBlackSingle/toyotaGT/workshop022.JPG http://supra.just2good.co.uk/myBlackSingle/toyotaGT/workshop032.JPG http://supra.just2good.co.uk/myBlackSingle/toyotaGT/workshop035.JPG http://supra.just2good.co.uk/myBlackSingle/toyotaGT/workshop036.JPG http://supra.just2good.co.uk/myBlackSingle/toyotaGT/workshop037.JPG At the same time I needed new bushes, new crank seal, new rear diff seal, new rear wheel bearing, new clutch, plus sorting of leaking oil return line and fuel return line. Not a cheap week! I can try and take more pictures of the support if you like, now it's all in situ. Link to comment Share on other sites More sharing options...
bignum Posted November 4, 2008 Share Posted November 4, 2008 Looking good, hope this 1 lasts a bit longer for you, whats that last picture, looks like the weld has been ground through. Link to comment Share on other sites More sharing options...
Dash Rendar Posted November 4, 2008 Author Share Posted November 4, 2008 I believe that's the custom support. But TBH, I haven't really got a clue! Link to comment Share on other sites More sharing options...
Homer Posted November 4, 2008 Share Posted November 4, 2008 Nice one Darren, have you had change to give it any beans yet? Boost issue now solved? Looks like the exhaust gasket was blowing too Darn XS power gaskets! I can see now why they were complaining about that one nut, thats even tighter fit than on the last manifold, must have been a nightmare to get to. I can't see any pics of the support, that last one is the underside of the dump pipe (which seems to have been refabricated as James had suggested). Link to comment Share on other sites More sharing options...
JamieP Posted November 4, 2008 Share Posted November 4, 2008 The last pic is the screamer pipe (looks like there is a couple of holes in it?) i cant see any customs supports in the pics. Link to comment Share on other sites More sharing options...
Dash Rendar Posted November 4, 2008 Author Share Posted November 4, 2008 Ah, right. Yes, they recommend relocating the screamer pipe as it was directed straight into the shell, so I asked them to go ahead and do that. I guess I'll probably need to take more photos of the support. Link to comment Share on other sites More sharing options...
Dash Rendar Posted November 4, 2008 Author Share Posted November 4, 2008 Oh yeah, it was blowing. It's got a decent gasket on there now. Here's some more photos of work done at the time... http://supra.just2good.co.uk/myBlackSingle/toyotaGT/workshop013.JPG http://supra.just2good.co.uk/myBlackSingle/toyotaGT/workshop014.JPG http://supra.just2good.co.uk/myBlackSingle/toyotaGT/workshop015.JPG http://supra.just2good.co.uk/myBlackSingle/toyotaGT/workshop016.JPG http://supra.just2good.co.uk/myBlackSingle/toyotaGT/workshop028.JPG http://supra.just2good.co.uk/myBlackSingle/toyotaGT/workshop038.JPG http://supra.just2good.co.uk/myBlackSingle/toyotaGT/workshop045.JPG http://supra.just2good.co.uk/myBlackSingle/toyotaGT/workshop046.JPG Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 5, 2008 Share Posted November 5, 2008 Third from last photo. All that red dust is from the outer C/V joint splines and the hub splines. The hub bearings slacken off, the splines start fretting, the metallic particles oxidise, and the only proper fix is a new or perfect driveshaft and a new hub flange, and a new hub bearing and seal assembly, properly torqued up. Just a new hub bearing won't last long at all.... Link to comment Share on other sites More sharing options...
Dash Rendar Posted November 5, 2008 Author Share Posted November 5, 2008 I don't know what that picture is, but what you're saying doesn't sound good. On a sliding scale of bad, I've no idea quite how bad. But it's all kind of irrelevent... I've spent the very last of my savings on this car this year. About 4 years worth of savings to be precise, and now I've got nothing left. So if there's anything else seriously wrong with it, then I'm just a bit stuffed. And here was me thinking the bad luck had finally come to an end! Link to comment Share on other sites More sharing options...
