Big brake kits
Luxluc
  • Replies 52
Sounds like something isn't quite right there Botachi. You've pretty much the same set-up as mine, but I've still got the ABS, and the pedal pressure is what I would call "perfect".
It could be that without the ABS pump the master cylinder size is wrongly sized, but it could also be air in the system, wrong spec fluid or wrong pad selection. Either way something doesn't sound quite right.
We run the Time Attack Supra's without the ABS pumps and there fine. Sounds like pads or air to me.
