Big brake kits
Luxluc
Similar to Wez's ecu register, I think it would be a good idea to have a front big brake upgrade register too, as many peoples (including myself) have questions on what to go for.
Upgraded rotors and pads on UKspec / Jspec pistons are not considered as big brake kits.
I would ask to those who have big brake kits on their Supe's post up. I suggest we take the following criterias :
1. Brake kit manufacturer
2. Number of pots
3. Disc diameter
4. Pad manufacturer
5. Rear brake upgrade - if done (braided line, pads, etc)
6. Personal comment on performance (1-10)
7. Brake fluid
8. Bhp
9. Supra use (%track and %road)
I will update the front page.
Cheers
  • SteveR - KAD - 6 pot 365mm - Porterfield pads --- Rear UK brakes with braided line and Portfield pads --- 10/10
  • JamieP - BREMBO - 6 pot 356mm (drilled) - Brembo pads --- Rear Brembo 345 mm (drilled) kit --- Brake Fluid : xxx --- 550 bhp --- track and road use --- 10/10
  • Uk-Rich - BREMBO - 6 pot 356mm (slotted) - Brembo pads --- Rear Brembo 345 mm (slotted) kit --- 10/10
  • T-Licence - AP Racing - 6 pot 360mm - Ferrodo pads --- Rear AP Racing 4 pot 330mm with Ferrodo pads --- Delphi Dot 5.1 fluid --- 550 bhp --- heavy road and track use --- 10/10
  • b'have - KAD - 6 pot 356mm - Endless pads ---Rear UK brakes with braided lines --- Motul 5.1 fluid --- 610 bhp --- track and road use --- 9/10
  • AshBhp - BREMBO - 4 pot 330mm (slotted) - Porterfield pads --- Rear UK brakes with Porterfield pads --- 10/10
  • csa - D2 - 8 pot 354mm - D2 pads ---Rear UK brakes --- Dot 5 fluid --- 550 bhp --- 5% track + 95% road --- 10/10
  • soonto"has"soop - BREMBO - 6 pot 398mm - Brembo pads --- Rear ?? ---Fluid ?? --- ??? bhp - ??? use --- ?/10
  • botachi - AP Racing - 6 pot 360mm (drilled/slotted) - Ferrodo pads --- Rear AP Racing 4 pot 343mm --- Motul RBF600 fluid --- 400+ bhp --- 20% track + 80% road use --- 8/10
Big brake.xls
Edited by Luxluc (see edit history)
  • Replies 52
Fronts:-
AP Racing
6 Pot
360mm disk (IIRC)
Ferrodo pads (will get part no. later)
Goodridge hoses
Rears:-
AP Racing
4 Pot
330mm discs
Ferrodo pads
Goodridge hoses
Awesome performance from a company that designs brake systems for top flight motorsport. 11/10 (just to beat Jamie's 10 :D )
KAD (same form factor as AP Racing brakes)
6 pot
365mm
Porterfield race pads
Uk Rears, Portfield pads as above
Fooking love them :D - cold/hot/track no worries. (Full weight 1500kg Supra) 10 out of 10. :thumbs:
edit - oh yeah, braided lines too.
Ok ... thanks Steve;)
Fronts:-
AP Racing
6 Pot
360mm disk (IIRC)
Goodridge hoses
Rears:-
AP Racing
4 Pot
330mm discs
Ferrodo pads
Goodridge hoses
:thumbs:
Boiled the fluid at Llandow (JP's fault) have improved the air ducting to the rear of the rotors now so that might help.
hmm ok thanks. I was runnning low boost so wasn't hitting the same highs are you. I'd have thought I'd cook them either their or at the 'Ring though, if they were cookable. I'll try harder ;)
Good idea Luc, I think a couple of factors need to be added in though. Brake fluid type and where they are being used, there's a big difference between road and track use. Also BHP might be a good idea as that has a bearing on how well the brakes can cope to.
yea good idea,
Track/street, 550bhp
Roger that Paul ... will be updated ;)
Fronts:-
AP Racing
6 Pot
360mm disk (IIRC)
Goodridge hoses
Rears:-
AP Racing
4 Pot
330mm discs
Ferrodo pads
Goodridge hoses
Delphi dot 5.1 brake fluid
550bhp
Heavy road use, Castle Combe, Brands Hatch, Silverstone, Nurburgring.
edited to add brake fluid and usage.
