Luxluc Posted November 4, 2008 Share Posted November 4, 2008 (edited) Similar to Wez's ecu register, I think it would be a good idea to have a front big brake upgrade register too, as many peoples (including myself) have questions on what to go for. Upgraded rotors and pads on UKspec / Jspec pistons are not considered as big brake kits. I would ask to those who have big brake kits on their Supe's post up. I suggest we take the following criterias : 1. Brake kit manufacturer 2. Number of pots 3. Disc diameter 4. Pad manufacturer 5. Rear brake upgrade - if done (braided line, pads, etc) 6. Personal comment on performance (1-10) 7. Brake fluid 8. Bhp 9. Supra use (%track and %road) I will update the front page. Cheers SteveR - KAD - 6 pot 365mm - Porterfield pads --- Rear UK brakes with braided line and Portfield pads --- 10/10 JamieP - BREMBO - 6 pot 356mm (drilled) - Brembo pads --- Rear Brembo 345 mm (drilled) kit --- Brake Fluid : xxx --- 550 bhp --- track and road use --- 10/10 Uk-Rich - BREMBO - 6 pot 356mm (slotted) - Brembo pads --- Rear Brembo 345 mm (slotted) kit --- 10/10 T-Licence - AP Racing - 6 pot 360mm - Ferrodo pads --- Rear AP Racing 4 pot 330mm with Ferrodo pads --- Delphi Dot 5.1 fluid --- 550 bhp --- heavy road and track use --- 10/10 b'have - KAD - 6 pot 356mm - Endless pads ---Rear UK brakes with braided lines --- Motul 5.1 fluid --- 610 bhp --- track and road use --- 9/10 AshBhp - BREMBO - 4 pot 330mm (slotted) - Porterfield pads --- Rear UK brakes with Porterfield pads --- 10/10 csa - D2 - 8 pot 354mm - D2 pads ---Rear UK brakes --- Dot 5 fluid --- 550 bhp --- 5% track + 95% road --- 10/10 soonto"has"soop - BREMBO - 6 pot 398mm - Brembo pads --- Rear ?? ---Fluid ?? --- ??? bhp - ??? use --- ?/10 botachi - AP Racing - 6 pot 360mm (drilled/slotted) - Ferrodo pads --- Rear AP Racing 4 pot 343mm --- Motul RBF600 fluid --- 400+ bhp --- 20% track + 80% road use --- 8/10 Big brake.xls Edited November 14, 2008 by Luxluc (see edit history) Link to comment Share on other sites More sharing options...
SteveR Posted November 4, 2008 Share Posted November 4, 2008 (edited) KAD (same form factor as AP Racing brakes) 6 pot 365mm Porterfield race pads Uk Rears, Portfield pads as above Fooking love them - cold/hot/track no worries. (Full weight 1500kg Supra) 10 out of 10. edit - oh yeah, braided lines too. Edited November 4, 2008 by SteveR (see edit history) Link to comment Share on other sites More sharing options...
JamieP Posted November 4, 2008 Share Posted November 4, 2008 1. Brembo MonoBlock front and rear Big Brake kit 2. 6 Pot 3. 356mm front 4. Brembo 5. 345mm rear 6. Best of the best,10. Drilled disks with braided lines. Link to comment Share on other sites More sharing options...
uk-rich Posted November 4, 2008 Share Posted November 4, 2008 .. Link to comment Share on other sites More sharing options...
uk-rich Posted November 4, 2008 Share Posted November 4, 2008 1. Brembo MonoBlock front and rear Big Brake kit 2. 6 Pot 3. 356mm front 4. Brembo 5. 345mm rear 6. Best of the best,10. slotted disc's here 10/10 Link to comment Share on other sites More sharing options...
TLicense Posted November 4, 2008 Share Posted November 4, 2008 Fronts:- AP Racing 6 Pot 360mm disk (IIRC) Ferrodo pads (will get part no. later) Goodridge hoses Rears:- AP Racing 4 Pot 330mm discs Ferrodo pads Goodridge hoses Awesome performance from a company that designs brake systems for top flight motorsport. 11/10 (just to beat Jamie's 10 ) Link to comment Share on other sites More sharing options...
Luxluc Posted November 4, 2008 Author Share Posted November 4, 2008 KAD (same form factor as AP Racing brakes) 6 pot 365mm Porterfield race pads Uk Rears, Portfield pads as above Fooking love them - cold/hot/track no worries. (Full weight 1500kg Supra) 10 out of 10. edit - oh yeah, braided lines too. Ok ... thanks Steve;) Link to comment Share on other sites More sharing options...
Luxluc Posted November 4, 2008 Author Share Posted November 4, 2008 1. Brembo MonoBlock front and rear Big Brake kit 2. 6 Pot 3. 356mm front 4. Brembo 5. 345mm rear 6. Best of the best,10. Drilled disks with braided lines. Update Link to comment Share on other sites More sharing options...
Luxluc Posted November 4, 2008 Author Share Posted November 4, 2008 slotted disc's here 10/10 Link to comment Share on other sites More sharing options...
Luxluc Posted November 4, 2008 Author Share Posted November 4, 2008 Fronts:- AP Racing 6 Pot 360mm disk (IIRC) Ferrodo pads (will get part no. later) Goodridge hoses Rears:- AP Racing 4 Pot 330mm discs Ferrodo pads Goodridge hoses Awesome performance from a company that designs brake systems for top flight motorsport. 11/10 (just to beat Jamie's 10 ) Link to comment Share on other sites More sharing options...
b_have Posted November 4, 2008 Share Posted November 4, 2008 (edited) 1. KAD 2 6 pot 3. 356mm 4. Endless pads 5. Rear brake UK braided 6. 9/10 7. Motul 5.1 fluid 8. 610 bhp 9. Tracked 2008 at Silverstone/Brands Hatch/Castlecombe/Marham/Llandow Edited November 5, 2008 by b_have update. (see edit history) Link to comment Share on other sites More sharing options...
Luxluc Posted November 4, 2008 Author Share Posted November 4, 2008 1. KAD 2 6 pot 3. 356mm 4. Endless pads 5. Rear brake UK braided 6. 9/10 Ok ... thanks Link to comment Share on other sites More sharing options...
SteveR Posted November 4, 2008 Share Posted November 4, 2008 Why 9/10 b'have? What made you feel the setup isn't quite 100%? Link to comment Share on other sites More sharing options...
b_have Posted November 4, 2008 Share Posted November 4, 2008 Why 9/10 b'have? What made you feel the setup isn't quite 100%? Boiled the fluid at Llandow (JP's fault) have improved the air ducting to the rear of the rotors now so that might help. Link to comment Share on other sites More sharing options...
SteveR Posted November 4, 2008 Share Posted November 4, 2008 Boiled the fluid at Llandow (JP's fault) have improved the air ducting to the rear of the rotors now so that might help. hmm ok thanks. I was runnning low boost so wasn't hitting the same highs are you. I'd have thought I'd cook them either their or at the 'Ring though, if they were cookable. I'll try harder Link to comment Share on other sites More sharing options...
AshBhp Posted November 4, 2008 Share Posted November 4, 2008 Front. Brembo F50 big brake kit 330 Slotted discs Porterfield pads Rear UK rear set up with Porterfield pads 10/10 Link to comment Share on other sites More sharing options...
Luxluc Posted November 4, 2008 Author Share Posted November 4, 2008 Front. Brembo F50 big brake kit 330 Slotted discs Porterfield pads Rear UK rear set up with Porterfield pads 10/10 Updated Link to comment Share on other sites More sharing options...
Paul Whiffin Posted November 4, 2008 Share Posted November 4, 2008 Good idea Luc, I think a couple of factors need to be added in though. Brake fluid type and where they are being used, there's a big difference between road and track use. Also BHP might be a good idea as that has a bearing on how well the brakes can cope to. Link to comment Share on other sites More sharing options...
JamieP Posted November 4, 2008 Share Posted November 4, 2008 Good idea Luc, I think a couple of factors need to be added in though. Brake fluid type and where they are being used, there's a big difference between road and track use. Also BHP might be a good idea as that has a bearing on how well the brakes can cope to. yea good idea, Track/street, 550bhp Link to comment Share on other sites More sharing options...
Paul Whiffin Posted November 4, 2008 Share Posted November 4, 2008 May be add in what circuits they've been tested on as that also has a bearing? eg. Brands Hatch max braking speed in my car is something like 130mph but then go to Snetterton and you've got 2 big stops over a lap, 160 and about 155mph. Link to comment Share on other sites More sharing options...
Luxluc Posted November 5, 2008 Author Share Posted November 5, 2008 Good idea Luc, I think a couple of factors need to be added in though. Brake fluid type and where they are being used, there's a big difference between road and track use. Also BHP might be a good idea as that has a bearing on how well the brakes can cope to. Roger that Paul ... will be updated Link to comment Share on other sites More sharing options...
Luxluc Posted November 5, 2008 Author Share Posted November 5, 2008 I've updated the criterias on front page. Brake fluid, Bhp and Use of the Supe (track or road) have been added. Updates and inputs welcome. Jamie : what fluid are you using? Link to comment Share on other sites More sharing options...
csa Posted November 5, 2008 Share Posted November 5, 2008 (edited) 1. D2 2. 8 pot with braided lines 3. 354mm 4. D2 5. UK spec stock rotors and pads 6. Wouldn't rate the D2's better than stock UK spec, but might be different when the Endless pads gets fitted 7. Dot 5 8. 550 9. 95% road, 5% track Edited November 5, 2008 by csa (see edit history) Link to comment Share on other sites More sharing options...
TLicense Posted November 5, 2008 Share Posted November 5, 2008 Fronts:- AP Racing 6 Pot 360mm disk (IIRC) Ferrodo pads (will get part no. later) Goodridge hoses Rears:- AP Racing 4 Pot 330mm discs Ferrodo pads Goodridge hoses Delphi dot 5.1 brake fluid 550bhp Heavy road use, Castle Combe, Brands Hatch, Silverstone, Nurburgring. Awesome performance from a company that designs brake systems for top flight motorsport. 11/10 (just to beat Jamie's 10 ) edited to add brake fluid and usage. Link to comment Share on other sites More sharing options...
b_have Posted November 5, 2008 Share Posted November 5, 2008 Updated. Link to comment Share on other sites More sharing options...
