dr_jekyll Posted November 3, 2008 Share Posted November 3, 2008 Hi, i have just installed an emanage blue in my 1994 n/a-t. Upon the first start the activation light changed from green to red indicating an error , the eror code flashes wer 2 flashes then a 5 second gap then 2 flashes again and this repeats i have gone through the intsalation and i cannot find any wireing faults , i have wired as follows emanage , car -------------------- red . ecu 12v black . sensor ground white . map signal out green . map signal in brown . rpm all conections are solderd solid, the only thing i think that could be wrong is the initial setting witch i have set for the 2jzgte (7,4,0) as ther is not list setting for the ge has anybody got any ideas , cheers Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 3, 2008 Share Posted November 3, 2008 Code 22 is no injector signal from channel 2. Quote Link to comment Share on other sites More sharing options...
bromy Posted November 3, 2008 Share Posted November 3, 2008 This is the wiring diagram for the injector harness, setting 740 is correct. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted November 3, 2008 Author Share Posted November 3, 2008 (edited) i see , i didnt think the injector harness was compusary . but i do have it so ill get fitting tomorrow , and see how we get on , thanks for the info and diagramme gentlemem. aditional , is that diagramm or theu plug faceing towards or away from you . Edited November 3, 2008 by dr_jekyll (see edit history) Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 3, 2008 Share Posted November 3, 2008 The view is looking at the plug from the wire side, i have a sneaky feeling that i used to get that error code on my old ENB even with the injector wires connected properly:blink: Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted November 4, 2008 Author Share Posted November 4, 2008 The view is looking at the plug from the wire side, i have a sneaky feeling that i used to get that error code on my old ENB even with the injector wires connected properly:blink: did you ever find a way to fix it or was it a fault with the unit itself ? Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted November 4, 2008 Author Share Posted November 4, 2008 ok fitting the injector harness has cured my error code , one other question on the matter . Will the emanage ultimate software on a laptop work on the blue ? Quote Link to comment Share on other sites More sharing options...
Ian C Posted November 6, 2008 Share Posted November 6, 2008 Will the emanage ultimate software on a laptop work on the blue ? Nope, it's completely different. But the software for the Blue is free to download from http://www.mohdparts.com so go there -Ian Quote Link to comment Share on other sites More sharing options...
