Starting Problems car choke??
Guest skans789
Guest skans789
Hello There My Car does'nt start when its cold but once you put Carbereter Cleaner in The choke it Fires Up With A Little Problem But Does start once ive put the cleaner in, Any ideas what it Is??
Thanks
ive got a J Spec supra twin turbo, might not be the choke then, its the big black pipe that you have to take off, and spray in to there.
Well I'm afraid that doesn't give much of a clue, but i assume you may be referring to the intake pipe to the throttle body, and if you spray carb cleaner in then i suspect it probably a sensor problem, but with you're lack of knowledge, i would be inclined to take it to a garage that knows what there doing with supras.
