GReddy breather tank and Fluidyne radiator
botachi
Hey guys,
I'm planing on installing a GReddy breather tank to help augment the efficiency of my cooling system. The thing is, the supplied unsprung radiator cap in the GReddy kit you use to mount on the radiator won't fit since the Fluidyne uses a bigger radiator cap. Will it be OK if I remove the spring of my old Fluidyne radiator, use it and install the GReddy breather tank or not use the breather tank anymore.
I also have a bnew 25psi STANT radiator cap which just arrived, not sure if I'll install that instead and forgo the GReddy breather tank. the GReddy breather tank raises pressure to 2bar, or just under 30psi.
Opinions?
