OverDrive Light Flashing..
Rob_B
Hi Guys..
I almost forgot about this problem until it happened the other day...
Every now and then when I give the Supe some serious welly :) I notice that the overdrive light flashes. I remember that this is some kind of diagnostic code so i noted the sequence... flash - 2 second delay - flash - 2 second delay, and so on, etc etc etc. Any of you guys know what this means ??
Rgds,
Rob.
Originally posted by Rob_B
Hi Guys..
Rgds,
Rob.
Rob,
I got that last week sometime. Only happened once. Couldn't find a code for it in the manual tho???
That was on the same morning as the flat tyre and when the alarm locked me out!!!
Gaz.
Originally posted by gazwalker
Rob,
Gaz.
:) Well along as the old 'Things happen in threes' is true, you shouldnt be expecting any other things to go wrong just yet :)
Rgds,
Rob.
Originally posted by eyefi
i think its something to do with overheating atf. does it do it when u use manual mode?
its not a diagnostic as such (unless u have shorted the diagnostic pins) its a warning
eyefi,
Not sure if it happens in manual mode, I'll try it on the way home from work and let you know :)
I haven't shorted the the diagnostic pins so I am guessing that it probably is overheating.
Thanks for the advice...
Rgds,
Rob.
eyefi,
Rgds,
Rob.
When I happened in mine I was in Auto mode, only set of 2 mins previously, wasn't giving it any grief at all...
Gaz.
