Stock autobox strength
TLicense
Following on from threads about the AEM controlling the autobox:-
http://www.mkivsupra.net/vbb/showthread.php?t=168079
I found this thread on the AEM forum:-
http://forum.aempower.com/forum/index.php/topic,1208.0.html
To sum up Jason from AEM has claimed that the stock autobox in any guise in not up to any significant power / torque increases.
However, I'm interested to see what power / torque people with autoboxes are running regardless of ECU.
So could people post up what power they are putting through their auto transmission?
If you've uprated the autobox in any way and are running more power then post up, but please also state what modifications have been done.
Don't worry about posting engine specs, all that I'm really interested in is
Autobox upgrades: (eg stock)
BHP: (eg 440 bhp)
Torque: (eg 400 ft/lg)
Mileage: (eg 100,000 total / 10,000 since upgrade)
ECU: (eg Emanage ultimate with stock autobox control)
Autobox upgrades: Stock + Stock TC
BHP: 497bhp
Torque: 440 lb
Mileage: 45,000(when upgraded / 5000 running this power
ECU: Emanage ultimate with stock autobox control
Autobox upgrades: BL + 3200 TC + coolers + Fans
BHP: 514bhp
Torque: 460 lb
Mileage: 1200 miles running this power
ECU: AEM
BHP: 514bhp @ 1bar / 550-580bhp (est) @ 1.4bar
Torque: 460 lb @ 1bar / 520 (est) @1.4bar
Mileage: 2000 miles running this power
ECU: AEM
Edited by rob wild (see edit history)
Looking forward to all the results on this thread as I'm having at present a PHR Street Single Kit fitted to my car on a Autobox & only upgrade doing on mine so far it fit a decent descent Mocal Oil Cooler to the autobox
Autobox upgrades: BL box, PI 4k RPM hi stall TC, 3x trans coolers. TRAC fuse always pulled - stock traction control ECU junked, this means the autobox gets a harder life
BHP: 11.5 @ 114 MPH, 11.92 @ 121 MPH. Power figures have never been realised - my car is incompatible with dynos :)
Torque: As above
Mileage: 52,000 total, 5,000 with hi stall and BL boxes, 3,000 ish on current BL box after breaking the first one (2nd gear sprag went)
ECU: MAP ECU2 (piggyback so stock ECU controlling autobox)
Driving Style: Hard on road, very hard on the drag strip with several full bore launches including 1.6 sec 60ft's
Added driving style as that's important information - people nursing stock boxes hides their durability IMO.
Cheers,
Brian.
Autobox upgrades: stock
BHP: 510
Torque: 458
Mileage: approx 80k total 35k of which at 1.2 bar BPU, 5K 1.4 bar T61
ECU: Stock and SAFC/ITC
when i went single and had my car mapped by Thor Pete told me the box was just starting to show the first signs of wear in that full throttle 2nd to 3rd gearchanges were not as quick as they should be, over time this got worse so i bit the bullet and installed the Boostlogic built auto with 3200rpm PI torque converter ~ present spec
Autobox upgrades: Boostlogic
BHP: 510 T61 @ 1.4 bar
Torque: 458
Mileage: 15k since install
ECU: SAFC/ITC (emanage ultimate to install when engine re-built)
the BL still changes up as fast as ever and allthough i drive simpathetically (ie warming the car up and cooling down properly) it does get its fair share of "spirited driving"
just a point on this, when i installed my Boostlogic gearbox i was a bit shocked at how hard the box banged into gear and it seamed a bit random some times it would change gear pretty smooth and other times it would crash into gear, i decided to disable the stock trac and all was well with the shifts being consistantly firm, i can only conclude that the stock trac conflicted with the way the Boostlogic box is set up
Guest SUP_R_G
me three, this could be very benificial to me when i have the v8 swap
sorry for the hijack, but where you getting this done? i was also interested in this:D
I have noticed with mine that when it's really cold it tends to shift pretty softly, then when everything heats up the firm and resounding clunk shift is there especially into 2nd.
Cheers,
Brian.
Can we keep the thread on track please. ;) This could be the information that a lot of people will need to decide on an upgrade path with their auto transmissions.
Total agree and I wish I had had this information 18months ago. My advice would to still to go down the "upgrade/strengthen" autobox route. However I think careful consideration needs to be given to were you source the upgrade from and to clarify what exactly has been done to the box. As a minimum I would expect the box to have been totally overhauled including all new seals, pump, pistons etc. I have had 2 BL upgraded boxes go but they have broken due to a faulty seal and pump (which weren't replaced at BL) However as far as strength is concerned that on the stock box (details above) Michel did find "wear" in the TC and the box itself. However the two BL boxes have been fine apart from the seals and pump. Therefore on using the BL boxes with a full WOT launch on a [email protected] did not break them i.e. 2nd gear sprag. Also I would consider the mapping had a great deal of effect on that as how much retard is used when shifting therefore lowering the power and stress on the components.
It might be interesting to get Robbie to comment on this thread regarding the amount of 1/4 mile runs that he did on his single bl setup. I know he managed a 10.66 1/4 @ suprapod 07.
