brake fluid
fruity_south
mmy uk spec calipers, 3g discs, pads and braided lines arrived today (thanks paul) just wondering am doing it all 2moro, what brake fluid should i use, and how much wil i need as will e draining it.
if your changing the lot it would be worth using dot 5 synthetic, i used 3 litres from halfords, also one of their self bleed kits are good and well worth a fiver, make sure you keep everything spotlessly clean
