Golfpro Posted November 2, 2008 Share Posted November 2, 2008 Golfpro, its running an aftermarket induction kit and there are no heat shields. If the car runs perfectly at other times and idles ok from cold then the heatshield may be your solution. It was for me. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 2, 2008 Share Posted November 2, 2008 First off i really cant See heat soak causing that sort of AFR figures, there is something ECU/sensor wise affecting hot idle AFRs. I would log injector duty cycle, duration, in relation to TPS, pressure sensor voltage, and see if it show what causing this, all other AFRs are within the expected range. Quote Link to comment Share on other sites More sharing options...
Stonkin Posted November 2, 2008 Author Share Posted November 2, 2008 Im slightly confused which version of software i should install from the site Homer posted. Does it need to be the same version as is currently installed on the EMU? If anyone has a guide i would be very thank full. Apologies if im coming across thick. Quote Link to comment Share on other sites More sharing options...
Stonkin Posted November 3, 2008 Author Share Posted November 3, 2008 Just a thought, but i know the car was mapped with Tesco 99 and i have mostly been using VPower, this wouldnt affect it would it? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 3, 2008 Share Posted November 3, 2008 Just a thought, but i know the car was mapped with Tesco 99 and i have mostly been using VPower, this wouldnt affect it would it? That shouldn't make any difference mate, as for the EMU software, presuming you have whatever full version installed on you're laptop, and if you don't have it installed, look for which of them is a full version and install, then just go for the latest version update, think its 2.20 now. Them when you connect to the EMU it should ask if you want to update the main unit, so just click yes and it will do this automatically. Quote Link to comment Share on other sites More sharing options...
Stonkin Posted November 3, 2008 Author Share Posted November 3, 2008 Thanks Tricky, just what i needed to know. Ive sent Ryan a pm to ask for his help when he is free Quote Link to comment Share on other sites More sharing options...
