Justin Posted September 2, 2002 Share Posted September 2, 2002 Dear more learned than me people. Please can you give me your thoughts on these questions as it seems a little tricky finding wheels to fit a Supra in the UK. It is wheely important! 1. From what part of the wheel is the width measured? Is it outsides of rims or just inside where the tyre sits? I took my wheel off and it measured 11 inches across. Do they make 11" wheels or is it a 10"? 2. Is the PCD 114.3 mm with 5 studs on the J-Spec 3. If I get 18" wheels with 255 tyres on rear what is the max profile size I should choose? 4. Is it best to get a thinner width pair of front wheels say 9" front and 10" rears? 5. What is the thinnest width of wheel I can safely and comfortably choose? Thanks for your time. Justin Quote Link to comment Share on other sites More sharing options...
Gordon F Posted September 2, 2002 Share Posted September 2, 2002 Originally posted by Justin 1. From what part of the wheel is the width measured? Is it outsides of rims or just inside where the tyre sits? I took my wheel off and it measured 11 inches across. Do they make 11" wheels or is it a 10"? Wheels are measured where the tyre sits so it is sometimes difficult to measure a wheel width with the tyre on. Normally the size is stamped on the rim. 5. What is the thinnest width of wheel I can safely and comfortably choose? I have 17x7.5 wheels all round but with stock size tyres front and rear and have never experienced any difficulties Quote Link to comment Share on other sites More sharing options...
Adam Kindness Posted September 2, 2002 Share Posted September 2, 2002 i have 9.5 x 18 on the rear with 275x35 rubber and 8x18 on the front with 225/35 rubber seem ok to me.... I stayed norrower on the front to avoid tramlining etc PCD is correct Quote Link to comment Share on other sites More sharing options...
GavinL Posted September 2, 2002 Share Posted September 2, 2002 Originally posted by Justin 5. What is the thinnest width of wheel I can safely and comfortably choose? Justin 5. Stock width's - Toyota chose those width's for a good reason. Quote Link to comment Share on other sites More sharing options...
Gordon F Posted September 2, 2002 Share Posted September 2, 2002 Originally posted by GavinL 5. Stock width's - Toyota chose those width's for a good reason. But surely Toyota chose every single part of the car for a good reason, and there aint many cars on this board that are 'as Toyota intended'. Quote Link to comment Share on other sites More sharing options...
GavinL Posted September 2, 2002 Share Posted September 2, 2002 Originally posted by Gordon Flynn But surely Toyota chose every single part of the car for a good reason, and there aint many cars on this board that are 'as Toyota intended'. That's true, but lets hope they are not less than Toyota intended Quote Link to comment Share on other sites More sharing options...
Justin Posted September 2, 2002 Author Share Posted September 2, 2002 Originally posted by GavinL 5. Stock width's - Toyota chose those width's for a good reason. As I bought the car with non stock wheels on could you tell me the stock widths. Thank you. Quote Link to comment Share on other sites More sharing options...
Syed Shah Posted September 2, 2002 Share Posted September 2, 2002 Stock widths: 8" front 9.5" rear 5. Go as wide as possible, nothing narrower than 255 on the back, and 235 on the front. 3. Max profile, 45 front and 40 rear, preferably 35 rear though. 2. Yes. 4. Yes, go thinner on the front than the back to help 'balance' the handling. 9" and 10" would be a good choice. Quote Link to comment Share on other sites More sharing options...
Alex Posted September 2, 2002 Share Posted September 2, 2002 The wider your tyres are the more prone to tramlining you become....its a balance of handling feel/composure vs. outright grip/footprint. I think 245 F and 275 R is a good balance for a Supra which is not stock. I've currently got 285's on the 9.5" rear and they are just a tad too big. Quote Link to comment Share on other sites More sharing options...
randy Posted September 3, 2002 Share Posted September 3, 2002 Excuse this!! Quote Link to comment Share on other sites More sharing options...
randy Posted September 3, 2002 Share Posted September 3, 2002 Just ordered 18/9.5 and 18/11 SSR GP-O decolte wheels from Mr. Paul Wiffin I will be running the 275/35s up front and 295/35's at the rear in Michelin Pilot Sport. I can't wait!! :flame Dev Quote Link to comment Share on other sites More sharing options...
ScottPawsey Posted September 3, 2002 Share Posted September 3, 2002 I have just brought some ace 18'' by 8.5'' running 265/35 on the rear and 235/40 on the front. It drives lovely, i haven't had any problems and they look good too!! Quote Link to comment Share on other sites More sharing options...
Justin Posted September 3, 2002 Author Share Posted September 3, 2002 Originally posted by Scott I have just brought some ace 18'' by 8.5'' running 265/35 on the rear and 235/40 on the front. It drives lovely, i haven't had any problems and they look good too!! Scott are they the ACE 197's? Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted September 3, 2002 Share Posted September 3, 2002 8.5" are too narrow for the rear. Randy, how much are you paying for the SSR's? Quote Link to comment Share on other sites More sharing options...
AJI Posted September 3, 2002 Share Posted September 3, 2002 Randy : Are you realy putting 275 width on the front? 255 width is the widest I've heard of for the fronts. The balance of grip front/rear is going to be drastically altered and with those widths on the front. You are going to be biased towards lots of oversteer in mid corner even without using rear wheel drive to get the back end out. That's just my personal opinion as although I've done a bit of car setup in the past I'm no expert. What do other guys in here think? Quote Link to comment Share on other sites More sharing options...
Andrew Dunk Shaw Posted September 3, 2002 Share Posted September 3, 2002 Hi Justin, On my last mk4 i had 9x18 fronts with 245x40x18 tyres and 10x18 rears with 285x35x18 tyres which worked really well, but the bigger width you go the worse the car tram lines. I think if you went up to 275 width on the front the car would tram line horridly, just my opinion !!! My new rims when they arrive are 9x18 and 10x18 as i know this wrks fine on a mk4, cant see any point in going bigger your just upping your tyre costs. Regards Andrew(dunk)Shaw Black uk mk4 tt Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted September 3, 2002 Share Posted September 3, 2002 It may be OK as he is keeping to the same front to rear differnces as stock, i.e 20mm wider at the rear. I personally run 235 at the front & 285 at the rear which works fine. Quote Link to comment Share on other sites More sharing options...
randy Posted September 3, 2002 Share Posted September 3, 2002 Originally posted by Terry Saunders It may be OK as he is keeping to the same front to rear differnces as stock, i.e 20mm wider at the rear. I personally run 235 at the front & 285 at the rear which works fine. That was what I was told 20mm is the same as stock (235/255)combo. Also I hear the larger tires in front help a lot in braking. Quote Link to comment Share on other sites More sharing options...
Syed Shah Posted September 3, 2002 Share Posted September 3, 2002 Originally posted by Scott I have just brought some ace 18'' by 8.5'' running 265/35 on the rear and 235/40 on the front. It drives lovely, i haven't had any problems and they look good too!! I think that a 265 tire is too wide for a 8.5" rim, I have 8.5" wheels on the front, and run 245s, which I was told is the widest safe choice for this width wheel. Quote Link to comment Share on other sites More sharing options...
Dragonball Posted September 3, 2002 Share Posted September 3, 2002 Syed Scott's are exactly the same wheel sizes as mine - on ACE alloys also - no problems at all Paul:cool: Quote Link to comment Share on other sites More sharing options...
Justin Posted September 3, 2002 Author Share Posted September 3, 2002 Originally posted by Andrew Dunk Shaw Hi Justin, On my last mk4 i had 9x18 fronts with 245x40x18 tyres and 10x18 rears with 285x35x18 tyres which worked really well, but the bigger width you go the worse the car tram lines. I think if you went up to 275 width on the front the car would tram line horridly, just my opinion !!! My new rims when they arrive are 9x18 and 10x18 as i know this wrks fine on a mk4, cant see any point in going bigger your just upping your tyre costs. Regards Andrew(dunk)Shaw Black uk mk4 tt Hi mate hope things are good for you. Thanks for the info, I'm not worried about bigger I was more concerned with how small the widths can be as my local wheel shop don't do that many wide wheels. Take care - Justin Quote Link to comment Share on other sites More sharing options...
