Red, Green or Blue Anti Freeze
Wez
Hey All,
I picked up some red anti freeze earlier for my car but when checking the application guide on the website it says I should be using the green anti freeze, anyone else come across this.
Both are ethylene glycol based products.
Xstream Green (recommended on site for MKIV supra)
http://www.commaoil.com/Product%20Pages/Coolantswinter/xstreamgreen.htm
Xtream Red
http://www.commaoil.com/Product%20Pages/Coolantswinter/xstreamredcon.htm
Super LongLife Red (what I have already purchased)
http://www.commaoil.com/Product%20Pages/Coolantswinter/superredconc.htm
Is there really that much difference between them?
I just called up Comma and spoke to a technical rep.
The red stuff is the wrong stuff, its Organic Acid Technology based and should only be used in motors that are designed for it.
The green stuff is Mono Ethylene Glycol based so they have different additives.
I asked about the Toyota stuff being red and was told the colouring is just a dye and different manufactors use different colours so shouldnt be used as a guide.
Looks like I need to go and change it :(
So it's not ethylene glycol based? :confused:
Yes it is but has organic acid technology as well, what ever that is.
No matter now as I have just swapped it over for the Xtreme Green they recommend which was 80p more.
Sounds like more tech speak bull to me, very little has changed in engine design material's, other than the grades of alloy used, so it would have to be seriously bad stuff to do any kind of damage;)
as said any Ethylene Glycol based stuff will be fine.
For the sake of 80p I changed it to the one they recommended.
I was told depends on the age of your car - red a-freeze can strip laquer off in minutes and won't be good for an old lady.
Organic acid technology is the salesman's line for dye in it. When the coolant gets old, or contaminated by combustion gasses, it becomes acidic. Like litmus paper the dye, which is organic, changes colour to announce to Joe Bloggs the coolant needs changing. As we are all smarter than Joe, and in a recession, there's no need for the fancy, and stupidly expensive stuff with dye in it. Just remember to change the el cheapo basic green stuff bi-annually and you'll be fine, and better off.
If you want to buy some really good coolant then evans is top notch.
demon tweeks sell a long life 180 degree boiling point long life coolant.
I just used the MR T red stuff.
Try to keep to same brand.
/type etc as it can congile if mixed but im not too clued up on this.
Mods, perhaps its time a sticky was put in FAQ and guides, that you can use any antifreeze, providing it meats current manufacturing spec , that way it will stop all this what and what not to use regarding antifreeze?
Good point, added it to the list of things to add.
