toyo rob Posted March 14, 2005 Share Posted March 14, 2005 simplish question really, just wondering how hard it is to check the turbo seals for a semi novice??? if it too time consuming, where the best place to go for someone in or about east london?? cheers Rob S Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 14, 2005 Share Posted March 14, 2005 It's all but impossible for this to be *successfully* done at home as to check the seals a full dismantle is required, and after dismantling it would be madness NOT to renew the seals and bearings and probably the shaft. Once renewed the assembly needs dynamic balancing, and assuming that you managed to get the thing stripped, sourced the repair parts and reassembled without drama (unlikely...), you won't have access to the air driven baancer required. No balance and the life of the unit is dramatically reduced. Just send the units to a Turbo Technics agent for rebuilding. A cheap rebuild is normally a bad rebuild, (re ground shaft with oversize bearing bushes, instead of a new shaft with stock size bushes, bead blasted wheels, often die ground up to remove dings, instead of new ones, blah blah. You get exactly what you pay for with turbo rebuilds, in my experience. Quote Link to comment Share on other sites More sharing options...
