bodilx6 Posted October 27, 2008 Share Posted October 27, 2008 What is the SOL and what is the MTR? Can I pull one/both and will that result in getting the TRAC system turned off on my J-Spec? Will it leave any side effects? http://onh93a.blu.livefilestore.com/y1pkTdUH0C004RkPCdZqCvDLLbQ4dWwMkq-kTyOJw5vvAwbyfkMD445T0iFL4CzqPHoue2XIUbHxm8/TRAC.jpg Link to comment Share on other sites More sharing options...
heckler Posted October 27, 2008 Share Posted October 27, 2008 i just removed the trac ecu... Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted October 27, 2008 Share Posted October 27, 2008 why dont you pull the fuse to it instead? Link to comment Share on other sites More sharing options...
imi Posted October 27, 2008 Share Posted October 27, 2008 room..... Link to comment Share on other sites More sharing options...
Thorin Posted October 27, 2008 Share Posted October 27, 2008 Your trac light will flash constantly if you just pull the fuse. I just hit the button to turn it off instinctively every time I start the car. Doesn't bother me. Link to comment Share on other sites More sharing options...
Gerry Posted October 27, 2008 Share Posted October 27, 2008 Your trac light will flash constantly if you just pull the fuse. I just hit the button to turn it off instinctively every time I start the car. Doesn't bother me. Thought I was told that pulling the fuse (which one ?) gave quicker times when on a drag strip ? Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted October 27, 2008 Share Posted October 27, 2008 Your trac light will flash constantly if you just pull the fuse. I just hit the button to turn it off instinctively every time I start the car. Doesn't bother me. trac light doesn't flash if you remove the fuse, it just stays illuminated, its the o/d light that has a slow flash but as i cant see it with my turbo timer in the way it doesn't bother me. Link to comment Share on other sites More sharing options...
Thorin Posted October 27, 2008 Share Posted October 27, 2008 Thought I was told that pulling the fuse (which one ?) gave quicker times when on a drag strip ? Nah myth IMO. On an auto the trac also smooths out the gear changes, even when disabled in the cabin. Pulling the fuse makes gear shifts more aggressive and might result in a faster time. Link to comment Share on other sites More sharing options...
paul mac Posted October 27, 2008 Share Posted October 27, 2008 Pulling the fuse makes gear shifts more aggressive and might result in a faster time. dont know whether this guy is auto or manual but disabling the track on an stock auto box will make for a harsher gear change and could lead to premature failure of the box Link to comment Share on other sites More sharing options...
Thorin Posted October 27, 2008 Share Posted October 27, 2008 dont know whether this guy is auto or manual but disabling the track on an stock auto box will make for a harsher gear change and could lead to premature failure of the box Manual going by his garage. Link to comment Share on other sites More sharing options...
bodilx6 Posted October 27, 2008 Author Share Posted October 27, 2008 i just removed the trac ecu... Cant figure where it is... Manual going by his garage. Yep, 6sp If the only side effect will be a constant light in the TRAC button, I'll just disable that as well. Whats the MTR and the SOL? And which one should be removed? Link to comment Share on other sites More sharing options...
Hermit Posted October 27, 2008 Share Posted October 27, 2008 i just removed the trac ecu... Does the ABS still work if you do that? Link to comment Share on other sites More sharing options...
Homer Posted October 27, 2008 Share Posted October 27, 2008 unplug the trac ecu is the simplest, it stops any error lights. Does the ABS still work if you do that? No, the ABS is a completely seperate ECU Link to comment Share on other sites More sharing options...
Hermit Posted October 27, 2008 Share Posted October 27, 2008 No, the ABS is a completely seperate ECU I guess you mean 'no it doesn't stop working' Reason I asked that is because although it's a separate ECU, the two communicate and there's an error code for that communication going 'wrong'. But if it doesn't think that disconnected is 'wrong' then that's cool, thanks Link to comment Share on other sites More sharing options...
paul mac Posted October 27, 2008 Share Posted October 27, 2008 Manual going by his garage. ahh i'll get my hat and coat then Link to comment Share on other sites More sharing options...
heckler Posted October 27, 2008 Share Posted October 27, 2008 trac ecu is next to the main ecu in the passenger footwell Link to comment Share on other sites More sharing options...
bodilx6 Posted October 27, 2008 Author Share Posted October 27, 2008 Aaaah.. thx. Thats what I needed. I'll take a look there Link to comment Share on other sites More sharing options...
