Heater fan squeal......
john Beckwith
Hi there -
Has anyone ever had problems with their heater fan / fan motor making a squealing noise. It sounds to me like either it needs a new motor or some kind of bearings have gone. At the moment the noise is intermittent - but definitely the blow air fan.
Any help would be much appreciated.
Cheers,
Johnb.
Thanks for the reply Matt.
I will endeavour to have a look see tonight - but as you say, I am a bit scared about taking the thing apart - I'll probably have to take everything out again!!
I'll hopefully have some funds available soon to come and see you over at the shop - still working on it.......
All the best,
Johnb.:thumbs:
I had this on a black TT aerotop I test drove at JIC, they said that it was just due to the heater and fans not being used for so long (due to the long importing process).
They said it would loosen up and stop after a while, and after being on for a while, it was considerably quieter. :)
Thanks for the feedback chaps.
I am sorry to say Syed that you were definitely getting the sales spiel there...... I have been using the fan pretty consistently and it only starts squealing when it has warmed up.
I had a go this evening at removing the front of the plastic casing and spraying in some WD40 a la Matt's suggestion, but after a test drive it is clear that it may need a little more persuasion than that.
I will go for Mark's suggestion at the weekend when I have a bit more light and time. Anything I need to know Mark?
Will report back when I have interogated the unit at the weekend.
Cheers,
Johnb.
Back again......
I took the fan out on Sunday and found two bits of twig and a litlle leaf in it. There was no need to strip down any further (even though I did try....;¬) - put the thing back in and all is quiet.......
Preparation - remove kick board in front of ECU and remove sill cover by passenger left foot. Trim can be removed by depressing centre pin.
Once these two items have been removed remove the power connctor (I found this a real bitch but a proper pair of loopy pliers does the trick) - then get on your back in the passenger footwell and remove the three retaining screws with a flat head screwdriver - (leave the cross-heads in place). Then it is just a matter of maneouvering the fan past the various looms on the way out.
You'll find it a piece of cake Alex - and peace and quiet restored.
cheers,
johnb
