Dave Posted October 26, 2008 Share Posted October 26, 2008 coming home last nite had a nasty grinding noise from the rear,suspected brakes sticking cause disc was red hot ,so stripped it all down this morning only to find one pad is like new the other [inner] is compleatly worn ,any idea why they havent worn evenly ???? caliper sticking ? anyways new set of pads on there way . Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted October 26, 2008 Share Posted October 26, 2008 Are they the smaller brakes? Possible caliper sticking if so. Quote Link to comment Share on other sites More sharing options...
simbasupra Posted October 26, 2008 Share Posted October 26, 2008 Do the smaller brakes have sliders? If so check they are free also check where the pads are located and ensure the worn one is not stuck in Quote Link to comment Share on other sites More sharing options...
Dave Posted October 26, 2008 Author Share Posted October 26, 2008 yes there the standard j-spec rears the caliper is sticking but i put that down to the piston coming to far out, it goes back in easy with a bit of pressure.will try new pads if that dont work looks like a new caliper:( Quote Link to comment Share on other sites More sharing options...
Dave Posted October 26, 2008 Author Share Posted October 26, 2008 Do the smaller brakes have sliders? If so check they are free also check where the pads are located and ensure the worn one is not stuck in when i put the new pads in will give everything a good clean, thanks didnt think of the pad sticking in the slider Quote Link to comment Share on other sites More sharing options...
simbasupra Posted October 26, 2008 Share Posted October 26, 2008 yes there the standard j-spec rears the caliper is sticking but i put that down to the piston coming to far out, it goes back in easy with a bit of pressure.will try new pads if that dont work looks like a new caliper:( doesn't sound like the piston sticking then if it goes back in under a bit of pressure. Quote Link to comment Share on other sites More sharing options...
simbasupra Posted October 26, 2008 Share Posted October 26, 2008 when i put the new pads in will give everything a good clean, thanks didnt think of the pad sticking in the slider yeah just check all moving parts are nice and free clean them up and put some fresh grease on. Quote Link to comment Share on other sites More sharing options...
Dave Posted October 26, 2008 Author Share Posted October 26, 2008 there nothing left on the inner pad just metal,belive it or not its just passed its mot Quote Link to comment Share on other sites More sharing options...
Dave Posted October 26, 2008 Author Share Posted October 26, 2008 thanks for the tips simbasupra top man ! Quote Link to comment Share on other sites More sharing options...
