pete.w Posted October 25, 2008 Share Posted October 25, 2008 been out in me car today and it started playing up and threatened to stall, as it re reved it puffed smoke out the back (major worry) ive done a diognostic check and ive got 2 ,code 41 and code 47 . anyone help with what these are ? Quote Link to comment Share on other sites More sharing options...
Hermit Posted October 25, 2008 Share Posted October 25, 2008 41 - throttle position sensor 47 - sub-throttle position sensor Hopefully the smoke was just it running very rich due to bad sensor input But it seems strange for both to go at the same time... could be a loose connector somewhere? Quote Link to comment Share on other sites More sharing options...
SimonT Posted October 25, 2008 Share Posted October 25, 2008 May be a stupid question but what tool do you need to check diagnostics codes? And where do you get one from? Quote Link to comment Share on other sites More sharing options...
Hermit Posted October 25, 2008 Share Posted October 25, 2008 diagnostics codes Click that Quote Link to comment Share on other sites More sharing options...
SimonT Posted October 25, 2008 Share Posted October 25, 2008 Click that Thanks Hermit!! Quote Link to comment Share on other sites More sharing options...
pete.w Posted October 26, 2008 Author Share Posted October 26, 2008 thanks pips for the replys , seems unusual to have two sensors go down at once ,is there a common wire that goes wrong or has a bad connection ? Quote Link to comment Share on other sites More sharing options...
Ian C Posted October 26, 2008 Share Posted October 26, 2008 Well now the ECU will store a code until it's reset, what it won't be able to do is give you a time or date. So the first thing to do is reset the ECU to clear all the fault codes and see if it still acts up. If it does, recheck the codes and the ones now present are the ones currently relevant. It's possible one or all of the stored codes go back years. Edit - gosh I was just about to add that advice to my original faq entry when I found I had already said it right at the bottom -Ian Quote Link to comment Share on other sites More sharing options...
