JZ TWINS Posted October 24, 2008 Share Posted October 24, 2008 (edited) Where can I find clips that plug into the dash button. I will also need a little bit of wire with the clips. I have an active spoiler and dash button already. Thanks Edited December 8, 2008 by JZ TWINS (see edit history) Quote Link to comment Share on other sites More sharing options...
Homer Posted October 24, 2008 Share Posted October 24, 2008 It's part of the engine bay loom so I think you'd need to get someone to seperate one from a loom, or if you're clever with electrics, make your own. There are some links to the ECU too, is it a USDM model? Quote Link to comment Share on other sites More sharing options...
JZ TWINS Posted October 25, 2008 Author Share Posted October 25, 2008 It is a US spec model. I was hoping someone sold there spoiler and the plug and wire is just hanging there. Along with the dash wire/clip. I saw the website how to hook it up but I wanted to try the oem clips first. Quote Link to comment Share on other sites More sharing options...
Guest Garfy Posted October 25, 2008 Share Posted October 25, 2008 it also requires a ECU mate, I wouldn't mess around with trying to get it to work with that, I would just make it work manually, I take it you found the TRL wiring diagram? Quote Link to comment Share on other sites More sharing options...
JZ TWINS Posted October 25, 2008 Author Share Posted October 25, 2008 (edited) Whats funny is I have two computers. I dont need them but they came with my parts. I was going to operate it manually with a relay but I wanted clips with wires so I could keep it clean. Does anyone have a couple for sale Edited October 25, 2008 by JZ TWINS (see edit history) Quote Link to comment Share on other sites More sharing options...
Homer Posted October 25, 2008 Share Posted October 25, 2008 Had a quick look at mine today (un-used Active Spoiler wiring), but it would be tricky to remove from the loom. If you get stuck one of these traders should be able to supply any parts you need: Jezz Keron Quote Link to comment Share on other sites More sharing options...
JZ TWINS Posted October 26, 2008 Author Share Posted October 26, 2008 I am not sure so I am asking.... Cant the wires be cut since it is not used anymore. Thank you for the replies Quote Link to comment Share on other sites More sharing options...
JZ TWINS Posted December 8, 2008 Author Share Posted December 8, 2008 Anyone??? please Quote Link to comment Share on other sites More sharing options...
Guest Garfy Posted December 8, 2008 Share Posted December 8, 2008 I've replied to your pm regarding this, I hope it helps Quote Link to comment Share on other sites More sharing options...
