Homer Posted October 24, 2008 Share Posted October 24, 2008 As title really, even when the car is locked up and verything is shut they stay on. Is it possible that the door open warning system is casuing the ignition light (green light around the ignition) to come on? I guess one of the door or boot sensors is not connected up... anywhere got an idea where to look for those? Quote Link to comment Share on other sites More sharing options...
heckler Posted October 24, 2008 Share Posted October 24, 2008 i'm pretty sure the boot doent have one, however the door sensors are part of the door latch system on the body of the car Quote Link to comment Share on other sites More sharing options...
Dave17 Posted October 24, 2008 Share Posted October 24, 2008 Have you got an alarm Homer? Since I got my Clifford 650 put in mine does what you describe as well, but only for 2 minutes. Quote Link to comment Share on other sites More sharing options...
Kev.O Posted October 24, 2008 Share Posted October 24, 2008 I once had this problm when I changed the door lock light to a blue LED one. It turned out that one of the LED legs was grounding out on the body work, fooling the system into thinking the car door was permanently open. Quote Link to comment Share on other sites More sharing options...
Homer Posted October 24, 2008 Author Share Posted October 24, 2008 i'm pretty sure the boot doent have one, however the door sensors are part of the door latch system on the body of the car Thats strange, there is sensor on mine, but I guess it's leftover from the Clifford alarm that used to be in the car, it's certainly not stock. Have you got an alarm Homer? Since I got my Clifford 650 put in mine does what you describe as well, but only for 2 minutes. Erm, no alarm at all, but I did rip out a Clifford as some of it was missing. Everything is plugged in but I guess the line must be cut into somewhere. The windows don't work either so I guess it's something left over from the alarm causing these faults... Quote Link to comment Share on other sites More sharing options...
Homer Posted October 24, 2008 Author Share Posted October 24, 2008 I once had this problm when I changed the door lock light to a blue LED one. It turned out that one of the LED legs was grounding out on the body work, fooling the system into thinking the car door was permanently open. Thanks Kev, good tip, I'll keep that in mind going through the wiring tomorrow! Quote Link to comment Share on other sites More sharing options...
absz Posted October 24, 2008 Share Posted October 24, 2008 sounds like its one of the door switches in the locking latch, pull out the dome fuse to see if the lights go out. Quote Link to comment Share on other sites More sharing options...
JustGav Posted October 24, 2008 Share Posted October 24, 2008 If you get really stuck and you can wait 2 weeks, I'll come and look at it Quote Link to comment Share on other sites More sharing options...
Homer Posted October 24, 2008 Author Share Posted October 24, 2008 sounds like its one of the door switches in the locking latch, pull out the dome fuse to see if the lights go out. Thanks Abs, will take a look at those tomorrow, hope it's not as they're a b*gger to get to! If you get really stuck and you can wait 2 weeks, I'll come and look at it Cheers Gav, much appreicated as always Hopefully it'll be solved by then! Quote Link to comment Share on other sites More sharing options...
Beefyblx Posted October 24, 2008 Share Posted October 24, 2008 As title really, even when the car is locked up and verything is shut they stay on. Is it possible that the door open warning system is casuing the ignition light (green light around the ignition) to come on? I guess one of the door or boot sensors is not connected up... anywhere got an idea where to look for those? This happened to my supra, On mine it was the plastic bit on the door that pushes the sensor when the door has closed, It came lose and wasn't pushing the sensor in far enough Quote Link to comment Share on other sites More sharing options...
Homer Posted October 25, 2008 Author Share Posted October 25, 2008 Fixed As normal, check the simple things first! I was missing the little stopper on the door that activates the door closed sensor. Also sorted the windows, I missed part of the clifford wiring which was chopped into the door wiring loom. Rewired and it all works. Thanks for the suggestions all Quote Link to comment Share on other sites More sharing options...
Kev.O Posted October 25, 2008 Share Posted October 25, 2008 Good one Homer. It's nice when things are a simple fix Quote Link to comment Share on other sites More sharing options...
