Dianogsis report
Dann
I bought some really expensive diagnostic kit the other day for my business and today I did a check on the supra and here are the results. As I am in training of how to use the equipment I am unsure what the results mean So be most grateful if you guys on her could let me know what you think.
MKIV 1996 N/A Toyota Supra
1) Engine speed 750 rpm
2) Injection Pulse Width 2.6 ms
3) idle control 39 step
4) air flow 0.59 v
5) intake manifold pressure 22 mmhg
6) left air fuel 0.00 v
7) right air fuel 0.00 v
8) throttle opening 0 deg
9) ignition advance angle 10 deg
10) Vehical speed 0 km/h
11) coolent temp 70 jae
12) Coolent temp sensor 4.28 v
13) L o2 sensor status Lean
14) R o2 sensor status Lean
15) L open closed loop Open
16) R open closed loop Open
17) Knock sensor No
18) Start switch off
19) idle switch on
20) a/c clutch off
21) p/n sw R-D-
22) warm start enrich no
23)Enrich after starting Yes
The supra has got fair few engine mods straight through exhaust no cats stainless manifold, arc induction kit ported ploished intake system and plenum. plus more.
Many thanks
Dann
