Britain's Bloodhound car could reach 1,000mph
SupraStar 3000
Saw this on the news this morning.
http://technology.timesonline.co.uk/tol/news/tech_and_web/article4996226.ece
It will be faster than a speeding bullet: a pencil-shaped car powered by a jet engine and a rocket, roaring across a desert at 1,000mph.
If all goes to plan, Bloodhound SSC will break the land speed record by the largest ever margin, and, in 40 seconds of breathtaking thrust, inspire thousands of British school children to take science A levels.
Today, at the Science Museum, the project to build this car will be announced by Lord Drayson, the Science Minister, who in 2006 first proposed the project to the two men who between them have held the land speed record for 25 years.
Richard Noble, engineer, adventurer, and former wallpaper salesman, reached 633mph (1,019km/h) as he drove a turbojet-powered car named Thrust 2 across the Nevada desert. In 1997, he headed the project to build the Thrust SSC, driven by Andy Green, an RAF pilot, at 766mph.
Wonder what the downforce would be like on a car at that speed? Probably drill itself into the ground!:D
Lots and lots.
The car will accelerate from 0-1,050mph (1,690km/h) in just 40 seconds; and at its maximum velocity, the pressure of air bearing down on its carbon fibre and titanium bodywork will exceed 12 tonnes per square metre.
Holy cr*p. It uses a V12 engine as a fuel pump! :)
http://www.bloodhoundssc.com/car.cfm
In the middle of the BLOODHOUND SSC is the MCT V12 800 bhp race engine which doubles as our APU delivering hydraulic power as needed, starting the EJ200 and of course pumping the High Test Peroxide (HTP) through to the Falcon rocket. The pump has to move a ton of HTP through to the rocket catalyst in 22 seconds and at 1200 psi. The beauty of the hybrid rocket is that it uses a safe and green oxidiser in the shape of HTP and only burns its solid fuel as long as the HTP is flowing. Shut the HTP flow off and the rocket shuts down in safety. No emergency problems of having mechanically to jettison a burning solid fuel rocket or running the risk of an explosion from shutting down a bi-propellant rocket with horizontal combustion chambers.
Cool!
When did you land that job Linda? :thumbs:
Well done you.
What part of the Typhoon does your company make?,.. or are you under the official secrets act. :taped:
:D cant say, secret ;) Actuator systems. Its only temporary, been here two months about to move onto a longer contract for more money :eyebrows:
Lxx
