Disconnecting Dash Gauges
Holeshot
I want to replace the lights behind the dash, the ones that flash up D,1,2 etc (auto) with this blue unit that came with the car unfitted.
Is there anything I should be worried about? Such as disconnecting the mph/kph converter which seems to have been screwed in on the back of the gauge pod.
What happens if I maybe whilst playing around with it I moved the fuel gauge needle out of the position it was in, will I need to adjust it back?
Any help appreciated.
i dont think there should be anything to worry about, i did my shift lights with blue LEDs
click on the link in my sig and it will show you how to take the dash apart, and just ignore the dials bit, to remove the shift lights there are two screws that need to be removed and the shift light board is clipped in, its a fairly easy job, good luck
