Question for WRC-turbo Upgrade for my MKIV!!!
WRC-Biturbo
I become my MKIV MT6 in the winter on 2 Corolla Wrc-ct20 turbocharger changes, furthermore WRC injection nozzles of the quantity 750CCM are used, would be it better a HKS VPC with GCC or directly a condition alone ECU to be used? At present I drive with HKS f-Con V pro.
best regards Thomas
From the looks of things English isn't your first language...so I'll give you the answer I think you're looking for.
Aftermarket ECU's (MOTEC etc) are the best option but they are also the most expensive.
Other wise the VPC and GCC is a tried and tested route.
Hello Alex
Thank you for answer, yes german is my first language, but i translate the question with bablefish.....
nest i answer i wrote by me self.
At the time my car run in true Turbo mode, last dyno was 440RWHP with Selfmade Downpipe, modified Head(ported & polished), HKS-Fcon V pro, and a selfmade Boostcontroller(manuell) Giken triple clutch, EGR is complett built up, including EGR-Cooler.
highist boost at more than 5000 U/min is 1,3 Bar at the midrange from 4000 i can drive 1,4 to 1,6 Bar. max EGT-Temp. is 700°C
and normally 660 to 680°c. Sparks are from Bosch 1 Point cooler then org. Sparks.
With the mods we do in Winter we will make min. 600RWHP.
best regards Thomas
