JamieP Posted October 21, 2008 Share Posted October 21, 2008 SOLD I have this setup from Innovate for sale Great kit for anyone going single turbo£250 Its got all the good stuff like the LM-1 proven kit, the auxbox that allows you to monitor tons of the cars parameters and plot against rpm for tuning and then the 52mm gauge so you can watch it when your not tuning on the laptop. Includes Innovate LM-1 Kit w/ Sensor Innovate Red DB 52mm Gauge Innovate AuxBox input/output kit The AuxBox attaches to the auxiliary input of the LM-1 and allows a user to log and analyze 5 critical engine metrics in addition to the air/fuel ratio native on the LM-1. The AuxBox makes the LM-1 into a complete tuning kit, allowing the user to capture, view, and analyze data on all 6 channels that the LM-1 can log internally. Correlating AFR, RPM, MAP, and CHT, for example, is essential when tuning piggy-back fuel controllers, ECU programmers, aftermarket ECUs, or racing carburetors. The 5 internal sensors are intended for capturing Manifold Air Pressure (MAP or Boost), Cylinder Head Temperature (CHT) or Exhaust Gas Temperature (EGT), RPM conversion (from a tach signal or inductive clamp), Acceleration, and Injector Duty Cycle (or Dwell). The internal MAP sensor is a 3-bar absolute pressure sensor, providing accurate data up to 44.1 PSIA. The temperature measurement circuit features a K-type thermocouple. The internal accelerometer features 2 axis measurements for a variety of mounting options. Another key application of the AuxBox is road testing. Even a dyno doesn’t provide as much real data as road testing. Factors like air flow, side force, and load vary significantly on a real road. With an AuxBox, a user can log 6 channels, in multiple sessions, for up to 44 minutes. Then, back at the garage, simply connect the LM-1 to you PC and view all of you log data. Use LogWorks to view fuel mapping, perform statistical analysis, overlay graphs, and playback a log on the virtual gauges. You can also view realtime data on LogWorks’ gauges if you want to take your laptop on the road. The AuxBox also includes 5 external inputs for connecting external sensors in lieu of the internal sensors. This allows users to log data from external sensors like TPS or suspension data. The AuxBox ships with mounting hardware, the LM-1 connecting cable, and the user manual. Link to comment Share on other sites More sharing options...
_Shane_ Posted October 21, 2008 Share Posted October 21, 2008 you open to an offer on this jamie first dibs please Link to comment Share on other sites More sharing options...
JamieP Posted October 21, 2008 Author Share Posted October 21, 2008 Not open to offers sorry, and it will work great on a twin turbo aswell:) Link to comment Share on other sites More sharing options...
JamieP Posted October 22, 2008 Author Share Posted October 22, 2008 Bump:) Link to comment Share on other sites More sharing options...
harley-jm Posted October 22, 2008 Share Posted October 22, 2008 Pmed Link to comment Share on other sites More sharing options...
JamieP Posted October 22, 2008 Author Share Posted October 22, 2008 SOLD to that man:) Link to comment Share on other sites More sharing options...
