Rocker Cover Gaskets
Guest SUP_R_G
Guest SUP_R_G
Hey folks, picked up my Supra the other day and goinf to fix a couple of little issues:(
Has anybody replaced the rocker cover gaskets and if so has anybody got any advice or tips etc?
Will be my first time doing such a job:blink:
do the bolts need to be tightened to a specific torque?
Probly yes but that almost impossible to find right torque so the best what you can do is turn bolt a little bit and another one and another and when you finish all you start again you do that few times to make sure you use almost same torque for every each bolt
cool, thanks for the info bud. getting a little oil leak at the front so ill beglad to get it sorted. just hope i dont mess it up.
Don't worry there is nothing what you can do wrong. Belive me if you start do it that and you know something about cars whole operation go smooth
Guest SUP_R_G
Be careful when tightening the cam covers back down, many a person has snapped the cam cover by over tightening. They are little more than hand tight (as the figures Rob posted show!)
New bolts and washers should be used, they are not reusable.
where would i get these spares ,toyota?
better do mine as its got a very tiny oil leak from the rear of the rocker cover, thought it was gb-oil until i removed the twin cats to fit a de-cat and found where it was coming from , still not bad for a 15 year old car lol
I've got some spare cam cover gaskets, left over from a gasket set. You can have them if you like.
I've reused the washers and bolts loads of times without any problem.
Edit to add:
Sorry, I'm on about TT ones. I didn't read the thread properly before posting.
Hi Jake,
I'm in need of some cam cover gaskets for a TT if you've got them spare? How much would you like for them?
