Apexi gauges problem
Guest sunnyG83
Guest sunnyG83
Hi people i have a problem with my Apexi Boost & EGT gauges.
Basically they have stopped lighting up when i turn my lights on but they still show the readings so are still functioning. The red needle lights up but the background/face does not light up any more.
I have attached a pic of the said gauges bellow. Any help would be great :)
Do the rest of your dash lights dim when you turn your lights on?
Do your lights (front of car) even come on?
Do they have a control unit or fed seperatly?
The more info you can give the better.
Did you buy these? or they already in the car?
Guest sunnyG83
Okay so the rest of my Dash lights are normal and are not effected buy the gauges.
The rest of my lights in the car and outside of the car work perfectly.
They are both wired into this :
I bought the car with these already fitted and they worked for 2 years without fail.
Edited by sunnyG83 (see edit history)
